k20 swap question
Old Jul 16, 2015 | 07:40 PM
fit613's Avatar
k20 swap question
Hey guys this is my first post here just acquired my 2007 honda fit with a knocking rod!!!
bought it as a project for 1000 bucks
already have the k20a2 fresh build and sleeved "going turbo" took stock fit motor out last night and i also ordered the has port mount brackets
I've got a question for the guys that have swapped the k 20 in there fits,I've tried the search option on the forum but came up with only one thread and that was back and outdated
is there new harness options?
and sorry if i missed a thread somewhere that had this covered
thanks guys
Old Jul 16, 2015 | 09:30 PM
MNfit's Avatar
As far and I know there are no new harness option other he. Wendi g your harness and the motor harness out to hasport (I think?) for them to slice it together. What I had done was picked up the k tuned universal harness and had the shop splice it in with the OEM fit harness. If I would do it again is hit up rywire for a customs harness.
Also make sure to check the top of the page there is a stick about the k20 swap
Edit: origanly posted from phone, I swear it looked coherent when I posted it!
Old Jul 16, 2015 | 09:33 PM
fit613's Avatar
thanks for the reply !!
i did indeed check the sticky thread ,was just curious so see if anyone went a differ rout. i contacted rywire they didn't seem to keen on helping me out...
i guess ill send hasport my 2 harnesses
Old Jul 16, 2015 | 09:52 PM
kylerwho's Avatar
spoon fed
call up brian at hasport. Last thing I heard, which was two years ago when I started putting together a list to kswap, was that they had a new single harness setup so that you wouldn't have to run a dual ecu setup. however be prepared to spend $1500 for it and to keep the interior stock look with the gauges and cruise control.
Old Jul 16, 2015 | 10:30 PM
fit613's Avatar
Going to call them tomorrow again
Did you keep electronic throttle?
Or switch to cable
Thanks for the help gentlemen
Old Jul 17, 2015 | 05:49 AM
kylerwho's Avatar
spoon fed
I never went with a k swap but I was around jpax frequently and he was running a dual ecu setup so that he could keep the stock gauges and cruise control.
I would try to keep things DBW.
Old Jul 21, 2015 | 12:40 PM
MNfit's Avatar
Or switch to cable
I am running a haltech, with a racepak. At the time I had the swap done it was pretty much common to swap from DBW to a cable. Not sure if now they can keep it cable or not
Old Jul 22, 2015 | 01:57 AM
kylerwho's Avatar
spoon fed
I just reread that you have a k20a2, means I would use a cable throttle. Jpax used a k20z3 so he stuck with the dbw.
Btw if you are looking to make some money off that l15a I would kindly take the head.
Old Jul 22, 2015 | 08:44 AM
fit613's Avatar
i will gladly give it to you just pay shipping
Old Jul 22, 2015 | 12:00 PM
domoMKIV's Avatar
Did you get in touch with hasport about the harness? Any info?
Old Jul 22, 2015 | 04:35 PM
fit613's Avatar
yes i did thank you for reminding me i forgot to update!!!!
so i contacted hasport again and they told me to supply them with the factory fit engine and charge harness and also a 2005 k20z1 harness---
good news is that i can now run only 1 ecu rather than 2
so now ill be using a 2008 tsx ecu with hondata k tuner and best part is factory cluster can now stay and will be working 100%
stay tuned I'm going to start a build thread as parts are already starting to arrive
Old Jul 22, 2015 | 06:39 PM
MNfit's Avatar
Fantastic news! Good luck with the build and looking forward to the thread
Old Jul 22, 2015 | 07:50 PM
Lance's Avatar
Good news to hear, that is the build I will learn from. I would like to keep a stock interior with a K swap in the future. Good luck dude.
Old Jul 22, 2015 | 08:33 PM
fit613's Avatar
Thanks guys!!! This will be full interior 750-800whp street car
stay tuned this will be fun
Old Jul 23, 2015 | 02:18 PM
domoMKIV's Avatar
Awesssoooommmmmeeee!! Thanks for updating!
Old Jul 23, 2015 | 06:27 PM
kylerwho's Avatar
spoon fed
That much power reminds me of the couture honda fit making 700whp and had push arm cbr1000rr rear suspension.
Old Sep 2, 2015 | 06:22 PM
Nicx1st's Avatar
Need some advice about the k-swap in a 2008-2010 honda fit
Hey everybody, I was wondering if i can get some advice from you about the Honda Fit K20 Swap… I’m in the process of doing the swap and want to know these answers:
1) Is the swap hard to do?
2) Is it the DC5 Type R K20a Engine with Transmission and with engine harness and Suspension, Brakes, Axles???
3) Which Radiator do i use? The one with the original Honda Fit or the one from the DC5 Type R??
I need some advice on how the swap is going to go.
Old Oct 27, 2015 | 08:20 PM
fit613's Avatar
sorry for late update been super busy but she's coming together and will be done soon!!!!
Attached Thumbnails k20 swap question-fit-one.jpg   k20 swap question-fit-2.jpg   k20 swap question-fit-3.jpg
StewMJC
Oct 4, 2018 12:41 PM
invalid
May 13, 2018 12:10 AM
fightinghamster
Jun 9, 2015 12:12 PM
FELIXY69
Oct 2, 2010 12:40 PM
gd_shane
Aug 9, 2007 09:05 PM
