Locksmith or new lock for door?
Old Aug 8, 2015 | 03:59 PM
dhoran's Avatar
Hi,
My driver's side door lock isn't working; it gradually became unusable.
A locksmith said he could put new wafers in for $75, and if it needs a new lock he could do that for $150.
What I'd like to know is - because this lock design is a bad design by Honda, will I end up having to pay for a new lock eventually? And I guess that lock will also go bad after 5 or so years....? (He did say he would replace the wafers with a different kind of wafer, which would last longer than the Honda wafers).
thanks a lot, Honda....apparently they've been using this lock design for years
Thanks for any feedback!
Old Aug 11, 2015 | 02:51 PM
are you talking about the actuator or the tumbler(?) ? i dont use the tumbler lock since the car has power locks, but if i did, i would lube it from time to time.
Old Aug 11, 2015 | 03:39 PM
dhoran's Avatar
I don't have power locks, so I guess it is the tumbler? In any event, lubricator does not help; there is something wrong with the mechanism inside. I'm surprised I did not get more replies; my research on the internet indicated this was a common problem with Fits. Thanks for taking the time, though.
Old Aug 11, 2015 | 05:08 PM
hummm..but it wasnt' like that from the getgo, right? i mean, if it was, you would've taken it in for warranty repair.
i dont' know about others, but most cars in the USA comes with bare essentials like power locks, windows, and a/c usually unless it's some special value package.
Old Aug 12, 2015 | 12:15 AM
Macswfc's Avatar
Do yourself a favour and get a new ignition key cut as well, if you are still using the original. I went through 3 locks and an ignition cylinder before they told me to get a new key....they wear quickly and cause a bunch of damage to the tumblers.
Old Apr 16, 2019 | 11:22 AM
DerrickHarris's Avatar
Mac is that the right thing to get the new ignition key cut by dealer or locksmith ?
Old Feb 28, 2020 | 09:45 AM
DavidEdwin's Avatar
For power door locks, try the dealer and for those which doesn't have power door locks, consider hiring a locksmith.
DavidEdwin's Avatar
Old May 21, 2020 | 07:52 AM
brandonnichole's Avatar
If the problem is in the ignition then there is no need to get a new key. Ask an auto locksmith to rectify the problem of the ignition so that keys will work fine,
Old Sep 29, 2020 | 09:28 PM
dll932's Avatar
Occasional lubrication of the locks is a real good idea. This is made specifically for that.
https://www.lockpicks.com/lokshot-69...-strattec.html
dongetti
Jan 22, 2024 10:05 AM
arkansasfit
Sep 15, 2019 04:37 AM
nigel_nz
Feb 14, 2017 03:48 AM
theloxmyth
Nov 18, 2012 06:12 PM
Hondafrk
Sep 22, 2011 03:08 PM
