2011 Honda Fit driver side mirror diy
Old Aug 25, 2015 | 11:33 PM
Aubs87's Avatar
My car was hit by a hit and run driver & the broke half my mirror off on my driver side. I bought a replacement off of eBay and am thinking of doing the replacement myself. It does not have LED just a standard manual fold-in mirror. Anyone out there have advice on how to replace whole mirror? Will I need to remove door panel? Thanks all!!
Old Aug 25, 2015 | 11:51 PM
xxryu139xx's Avatar
there is a video on youtube showing how to remove the door panel, that would help u alot.
once u get that off, there's a little semi traingular panel between the door and the windshield. pop that off and there are 3 screws. ull have to remove that and the mirror will pop off.
with window up, and door panel off, theres a white insulation plastic covering the door hole where the wires are. ull the blue harness clip ull need to unplug. u may have to pull that off the rubber boot/grommet. if you're having trouble getting it thru since the mirror is junk anyway, u can cut off the harness clip and pull out the harness.
now reverse installation with new mirror. ull have to snake the new wires thru that boot. if u can unclip the wires from the plug it will make it so much easier for u. just remember which wire goes to what hole. once u do that, get a long wire like a wire hanger and stick in thru the far opening by the door and snake it all the way up the other end. make sure it has a hook at the end, then tape your wires to the hook. try to flush the hook as much as possible or it will catch on the boot. pull the wire hangar back out and guiding it thru the bends. once u get it thru the rubber hose/grommet, push it thru the door and thru the hole. hook it up the harness plug and ur good.
and good luck =p
Old Aug 26, 2015 | 12:22 AM
Aubs87's Avatar
and good luck =p
Thanks so much for your help! I will definitely try this! Sounds pretty easy and less expensive than taking it to a shop!!
Old Aug 26, 2015 | 12:42 AM
xxryu139xx's Avatar
the hardest part is the rubber grommet.
Old Aug 26, 2015 | 06:18 AM
Black3sr's Avatar
The coat hanger going through grommet not required. Just the removal of the door panel and the triangular piece is all that is required.
This is a good thread https://www.fitfreak.net/forums/2nd-...s-winkers.html
Old Aug 26, 2015 | 11:06 AM
Aubs87's Avatar
I think I've seen then the YouTube video! Thank you for your input!!!
Norm24
Mar 5, 2024 09:34 PM
timfield
Mar 24, 2011 10:06 PM
estlin
Jun 23, 2010 12:07 PM
proletariandan
Jun 1, 2009 01:25 AM
jimmyparky
Dec 5, 2008 07:58 AM
