Alarm/starter
Old Oct 12, 2006 | 01:12 PM
whiz's Avatar
Alarm/starter
Hey
Should be getting my fit in about a week and i'm looking to get a remote start and alarm. I've bought a 5spd sport has anyone installed either of these yet. I searched but didnt see anything.
Winter is not fun without a remote start.
Old Oct 12, 2006 | 02:16 PM
fireman27c's Avatar
Old Oct 12, 2006 | 02:24 PM
whiz's Avatar
thanks man dunno how i missed those
Old Oct 12, 2006 | 09:06 PM
2hot6ft2's Avatar
Exclamation Not a good idea with a M/T
Originally Posted by whiz
Hey
I wouldn't put a remote start in my M/T since you have to bypass or eliminate the clutch in to start safety feature for it to work. You would be better off going with a block heater. https://www.fitfreak.net/forums/fit-diy-repair-maintenance/8864-block-heater.html
It would be a shame if you remote started your car and it took off down the road without you, went thru a wall, ran into another car, RAN OVER A CHILD. Up to you but it's not the best idea for warming up a M/T on a cold morning.
A block heater on a timer does just fine and it's a lot safer. Just don't drive off with it plugged in !!!
Old Oct 13, 2006 | 12:03 PM
whiz's Avatar
Originally Posted by 2hot6ft2
I wouldn't put a remote start in my M/T since you have to bypass or eliminate the clutch in to start safety feature for it to work. You would be better off going with a block heater. https://www.fitfreak.net/forums/showthread.php?t=8864
Car comes factory with a block heater. I have no access to a plug at work because i park on the street. I leave my car in N all the time with the Parking break on so its not going anywhere. The remote will also show the car is running and for how long (aslong as i go with a pager alarm)
Old Oct 13, 2006 | 07:18 PM
2hot6ft2's Avatar
You're the first one I've heard of that a block heater came factory installed, or did you order it that way ? Anyone else have one factory installed ? Are you sure the dealership didn't install it ? What model did you get since kps is in Canada and got a sport LX and his didn't come with one as standard equipment I'm sure he would like to know ?
As long as you know what you're doing the only thing stopping you is the clutch safety switch feature. You'll probably have to install it yourself since there would be a liability issue with a professional or business installing it for you. So go for it. I've done it myself but on an automatic vehicle. It's not all that difficult, just follow the instructions that come with it.
Good luck.
Old Oct 14, 2006 | 10:23 AM
kps's Avatar
kps
Honda Fit Forums Moderator
All the options beyond model and transmission are dealer-installed. I forgot to order the block heater as an option because I ordered in the middle of summer.
Old Oct 14, 2006 | 05:18 PM
2hot6ft2's Avatar
Same here and I didn't even think about the block heater when I got mine since summer just started.
Old Oct 16, 2006 | 06:39 PM
whiz's Avatar
by comes factory i ment i asked for one
Old Oct 16, 2006 | 07:48 PM
2hot6ft2's Avatar
Ok, that makes sense. Good luck with the remote starter.
Old Nov 18, 2006 | 07:05 PM
alarmgui's Avatar
Several companies make RS that is Manual compatible...Scytek (scytek.net) in N. Hollywood, CA, and Clifford (directed.com - Vista/San Diego, CA) Concept and IntelliGuard series will do RS with the IntelliStart4. The Matrix line will NOT do it so no 2 way from them. Directed also makes an Imobbiliser bypass that doesnt need an extra key.
Old Nov 19, 2006 | 03:08 AM
kz098123's Avatar
Call around to different car stereo shops. I called about 12 different ones and found only 1 that would install a starter on a M/T.
I'm having it installed in a couple weeks.
Old Nov 19, 2006 | 05:18 PM
alarmgui's Avatar
If anyones in SoCal (Fontana - San Bernardino) area and needs alarm work, let me know. It's what I've been doing for 17+ years
Old Dec 4, 2006 | 11:18 PM
TeamEMC's Avatar
Remote Start on M/T Fit
Just finished installing a Remote Start & Alarm on my M/T Fit. Had no problems took me about 6 hours. Took my time to do it right. Works great. The Unit is a JTI, Jt 400S with manual transmission reservation. I also used a transponder bypass kit, no extra key was needed...
Old Dec 5, 2006 | 07:08 AM
kz098123's Avatar
Had mine installed on my Sport M/T last friday. It was an Ultra Starter brand alarm/starter. www.ultrastarters.com
Works pretty well, I'm happy with it. Sure beats getting into a cold car in the dead of winter.
Old Dec 5, 2006 | 01:03 PM
kz098123's Avatar
Originally Posted by rinaedin
any idea on range of costs?
~$500-600 for an alarm with remote start installed on a M/T
ctyt
May 22, 2017 05:57 PM
intiaz_k
Dec 30, 2014 04:06 PM
Raincloud44
Oct 15, 2012 12:02 PM
VictorFarias
May 24, 2012 11:33 PM
kimo
Apr 5, 2007 09:05 PM
