LED Conversion complete.
Old Nov 14, 2015 | 10:38 PM
pacothebandit's Avatar
Just converted my fogs and headlights to LED from V-LED dot com.
I have to say this project should not have taken as long as it did. First off I couldn't figure out which way to rotate the lights so that the light guards didn't aim the light the wrong way. After that we couldn't get the metal bracket that holds the bulb in place over the cooling fins. Finally we succeeded and this is the end result.
Right: fog light LED 4500k Left: headlight LED 6k
Old Nov 15, 2015 | 12:08 AM
xxryu139xx's Avatar
love vleds. u mind sharing a picture of your headlight cut off against a wall 25 feet away?
Old Nov 15, 2015 | 12:48 AM
Not at all. Soon as I get a chance.
Old Nov 15, 2015 | 08:58 PM
Best I could do, not to many places to do that around here. Not sure why there is a split in the lighting.
without fogs on
Fogs on
Attached Thumbnails LED Conversion complete.-80-img_1753_eb2d609093d48a13a4c6cce406d276a6db14426f.jpg   LED Conversion complete.-80-img_1752_cc28f22b6c768fe6f0044ab8572d205b3b7cc29b.jpg
Old Nov 15, 2015 | 09:03 PM
xxryu139xx's Avatar
could be a better cut off. would be better to see on an even wall.
Old Nov 15, 2015 | 09:23 PM
maybe I dont get what you mean by cut off. we weren't sure if the deflectors were facing the right way
Old Nov 15, 2015 | 09:57 PM
xxryu139xx's Avatar
here is my cutoff from my projectors
Attached Thumbnails LED Conversion complete.-img_20140608_201906_zpspk6r9lwg.jpg
Old Nov 15, 2015 | 10:27 PM
cajlog's Avatar
With v-leds, do you still need to have projectors ?
Old Nov 21, 2015 | 03:09 PM
Nope. Are you talking about supposed to from a legal standpoint it? Or from the hardware fitting?
Old Nov 21, 2015 | 03:11 PM
Boom. There we go. I don't like how it's split in the middle. From further distance it seems like the light shines in the air but I haven't been flashed by incoming drivers so it must be fine.
Attached Thumbnails LED Conversion complete.-80-image_3da321921b5bd9aa9df29272398044b0813a4822.jpeg   LED Conversion complete.-80-image_0744a906299a432947b7dcf7221292a3db2da7ee.jpeg
Old Nov 21, 2015 | 03:21 PM
xxryu139xx's Avatar
looks like the cut off still isnt comparable to real projectors for LEDs. your passenger side seems a little high, but that is not really an issue since a little higher is good for lighting up signs on the right side of the road.
Old Nov 23, 2015 | 03:38 PM
solbrothers's Avatar
Loving that retrofit up there. The led lights, not so much.
Old Dec 2, 2015 | 02:40 AM
koolkevin1107's Avatar
That's one of the ugliest light outputs i've ever seen. Please put your oem bulbs back in there, you will have way more light output. LED's as headlight bulbs are a gimmick, sorry to say. I'd recommend getting a real retrofit done using the Morimoto mini H1 7.0 projectors.
Old Dec 2, 2015 | 10:04 AM
^yep. Please go back to stock. For your safety and other drivers you share the road with
Old Aug 16, 2016 | 05:01 AM
Gakidou's Avatar
I have a question. I own an 08' Fit sport 5spd AT. I have stock halogens in original assemblies. I want to convert it to LEDs feom VLEDS.com, i want to put these specific ones in it: H4 LED HEADLIGHTS HIGH/LOW HIGH OUTPUT LMZ PLATINUM 45W . Can i do that with the stock wiring in my car and headlight assembly or do i neednother aftermarket parts?
Old Aug 16, 2016 | 07:45 PM
dwtaylorpdx's Avatar
The wiring will be fine the stock bulb likely pull more current than the LED does, but the reflector/LED combo is very specific, and if the bulb and reflector don't match the out put will suck, and or be awful for oncoming traffic..
Old Oct 5, 2016 | 08:20 PM
Gakidou's Avatar
I bought the headlights i was wanting and have come across a small hiccup, the rubber weather seal is slightly in the way of the thermal heatsink/fan on the back of the bulb. Any suggestions on how to get around this or do I really even need it in place?
Old Oct 8, 2016 | 07:22 AM
Morgan Yarbrough's Avatar
I just tried two sets of LED headlights and both had major beam pattern issues. I put the halogens back in... Read more here: https://www.fitfreak.net/forums/fit-...ht-review.html
calafricano
32
Nov 29, 2019 11:57 AM
Nightime
Feb 10, 2016 09:39 AM
eCity Fit
Sep 9, 2014 07:58 PM
