Making Miata wheels fit the GK?
Old Dec 12, 2015 | 10:33 AM
matthorkan@gmail.com's Avatar
I'm a new honda owner, after having chevrolet and mazda sports cars since i turned 18. Its nice and cheap, stick shift and dead simple, but with almost 20,000 miles my fit has already eaten its set of firestones and is actually making quite a bit of road noise. Since i have the LX, i have the ugly steel wheels and would like to fit some miata wheels i already own instead.
The question is that i wonder if its difficult to resize the center "bore" of the wheel without doing it wrong and making the whole thing make noise. Should i fit some kind of rubber to it? Would this make my speedometer not accurate?
Here is a photo of what i had in mind. I hope the GK looks good on them. I'm going to have to paint them anyway, so what sort of color do you guys think would look good with yellow?
Attached Thumbnails Making Miata wheels fit the GK?-102227d1391646924-2001-mazda-miata-6100-obo-1011365_10201153397573019_1611662250_n.jpg
Old Dec 13, 2015 | 11:10 AM
GolNat's Avatar
Get some hub ring adapters. Your speedometer accuracy will depend on the size of the Miata tire compared to your stock tire size.
Silver, gunmetal, or black would look nice.
Old Dec 13, 2015 | 11:24 AM
ok, i know this wheel is usually 195/50-15. A great tire size if you want performance or summer tires (Which sadly i cant get with the OEM size) How inaccurate will that be?
Old Dec 13, 2015 | 01:28 PM
Action Jackson's Avatar
The bore size for Mazda's is typically in the 54~ mm.
Honda's are typically 56~mm.
He's asking about enlarging the bore size for his Miata rims.
Old May 12, 2017 | 09:19 AM
F-BOMB's Avatar
I've been considering the same thing. The Miata aftermarket rivals the Mustang market!
I'm always checking my local Craig's List for Miata wheels.
I found this website that has great options (and prices) that could work for our cars.
http://www.good-win-racing.com/mazda/miata/process.html
Old Aug 31, 2017 | 02:07 PM
domoMKIV's Avatar
I have miata bbs from the 95 m edition on my Fit. You'll have to find a machine shop that you can trust to do the work.
Old Sep 1, 2017 | 02:55 AM
dwtaylorpdx's Avatar
Stockton Wheel used to do that kind of work...
Old Sep 2, 2017 | 08:07 AM
miata's run 4x100 i suppose?
Old Sep 2, 2017 | 12:15 PM
Rob H's Avatar
1st, 2nd and current generation run 4X100. The 3rd generation ran 5X114.3 or 4X4.5" The issue that an earlier poster eluded to is that Miata have a 54.1 hub bore compared to Honda's 56.1mm hub bore. So the wheels would need to be put on a lathe to enlarge the hole for Honda or other fitments.
Old Sep 3, 2017 | 04:28 PM
interesting, thanks for the info rob.
Old Oct 29, 2018 | 05:16 PM
mnautox's Avatar
14x6 miata tires/rims, $80 for the set, about 1.5hrs working the inner hubs to fit.
For the DIYers: will need a cutoff tool, buy a bunch of cutoff discs (break off the discs to fit within the hub area, the disc wheel will become circular as you use), slowly grind off the inner hub material, check for fitment, go to the next wheel. Honda people usually want an arm & leg for old oem wheels, usually Miata guys cant wait to get rid of their wheels for cheap.
bbakerga
Jun 20, 2017 09:22 AM
Carbuff2
Oct 4, 2015 06:33 AM
Carbuff2
Aug 5, 2015 09:49 AM
nicco
Mar 25, 2015 06:57 AM
madtodaimax
Dec 24, 2014 11:18 PM
