Cabin Blower Fan doesn't work
Old Dec 16, 2015 | 06:05 PM
jekokmey's Avatar
Recently the AC / Heater blower fan stopped working intermittently and now doesn't work at all. 2009 Fit Sport is the model and I already replaced the resister and still doesn't work. Pulled the fan out and tested, works fine when hooked up to power. Have not checked the fuses but nothing else seems to be failing.
Is there anything else I can check for or I'm I missing something?
Old Dec 16, 2015 | 09:04 PM
DrewE's Avatar
Sounds like you have some basic electrical system troubleshooting ahead. I'd probably start with the ground for the blower motor, and if that looks good, check the fan speed switch and its connector.
Old Dec 22, 2015 | 06:25 PM
dwtaylorpdx's Avatar
Always start with the fuses..
Yep you've got something either not hooked up(Broken wire) or a switch or relay failure, I'd follow the wire back from the fan and see where the power stops in the circuit. Probably try the switch first. I use a little fluke hand meter..
Faoladh
Aug 17, 2017 10:06 AM
seanpatrickk
Aug 10, 2015 07:32 PM
Marrk
Sep 29, 2013 02:19 PM
Trogdor!
Sep 17, 2010 04:33 PM
TeGGeR®
May 15, 2005 07:30 PM
