Radiator fan question
Old Oct 16, 2006 | 03:17 PM
Edward Man's Avatar
I notice the radiator fan turns on quite often, even when the outside temperatue is around 10C and the car had being running for about 10mins!! Is this normal?
Old Oct 16, 2006 | 04:59 PM
quangalang's Avatar
yes it is normal
Old Oct 16, 2006 | 10:53 PM
wyy183's Avatar
Once the engine is warmed up to normal operating temperature (around 175 degrees Farenheit) and you come to a stop, or are going through town where there isn't a lot of air flow through the radiator, the fan will come on when the coolant temperature reaches 200 degrees. It doesn't take very long - so, in that case, I would say that it is probably normal.
Another thing - if you have your defroster on, then the air conditioning compressor is cycling off and on. When the A/C is on, the fans are on, too!
gerard6496
Jan 12, 2024 02:12 AM
wzard999
Nov 17, 2013 08:58 PM
RUFit
Jan 29, 2009 03:14 PM
fit4jdm
Oct 21, 2008 01:39 AM
Mugen_Dom
May 13, 2006 10:18 PM
