HID issue
Old Jan 14, 2016 | 01:28 PM
gabriel0830's Avatar
HID issue
Okay im installing HIDs in my 07 Fit(auto) but when i plug in the hids and turn in the lights, it doesnt come on... however the HID high beams work.. when i remove it and install the oem headlight.. it turns on perfect.. i checked and checked my wiring but its perfectly fine bcuz like i said my high beams r on but the low beam is not
help me out?
Old Jan 14, 2016 | 03:35 PM
Desmond Lamar MacRae's Avatar
help me out?
Did you remove the DRL's fuse? There isnt enough wattage to power the bulbs. Let me know if that works.
Old Jan 14, 2016 | 03:43 PM
i did not! but i will right now!! where is the fuse located?? mines the base model.. does that matter?
Old Jan 14, 2016 | 04:00 PM
fused removed and still no power to the HID low beams... im probably going to have to run a relay to the battery
Old Jan 14, 2016 | 04:29 PM
xxryu139xx's Avatar
do u have a ballast? those need a relay to the battery.
Old Jan 14, 2016 | 10:29 PM
He's right. My HID's came with a wiring harness that includes free in the kit. My fuse burned and. I only had brights in that bulb. I totally forgot about that.
Old Jan 15, 2016 | 01:06 AM
i just boght the relay.. will install tomorrow hopefully!! thanks for your help guys
1toughfit
Sep 27, 2013 07:09 AM
stnl619
Dec 24, 2009 12:40 PM
panda1314
Jan 13, 2009 02:57 PM
Domo3234
Aug 19, 2008 12:52 AM
fitster
Jun 6, 2008 04:24 AM
