1997 Honda Fit acceleration proble
Old Jan 26, 2016 | 10:24 PM
Jwallycars's Avatar
Smile 1997 Honda Fit acceleration proble
Hi all,
I am a newbie on this site and am seeking some advice.
My 97 Fit with manual transmission has 130,000 miles and has been running like a top until recently.
The car idles just fine. During acceleration in any gear it jerks/hesitates getting up to speed. The harder you push it the worse it is. I hardly notice it when gently accelerating.
Should I be focusing on adjusting the valves as it has never been done? The plugs have been changed within the last 20,000 miles.
Any thoughts on what might cause this would be appreciated. Thanks
Old Jan 26, 2016 | 10:30 PM
xxryu139xx's Avatar
1997? must be some prototype
Old Jan 26, 2016 | 10:39 PM
cajlog's Avatar
Bump for research purposes.
97 ?
Old Jan 26, 2016 | 11:07 PM
There's no 1997 Fit.
Not sure why this hasn't been closed.
Old Jan 26, 2016 | 11:13 PM
xxryu139xx's Avatar
waiting maybe he made a mistake, but since u did post in it, i may have to just because lol
Old Jan 27, 2016 | 09:42 AM
Carbuff2's Avatar
Anyway, if it's an '07,
Valves should be adjusted for sure, and you should consider replacing the coil-packs over the spark plugs with OEM or Hitachi's part number ending in 053.
While you are doing that, verify that the proper Iridium plugs were installed 20K miles ago. Other types will NOT last.
Make sure to post back with the outcomes.
Old Jan 28, 2016 | 01:50 AM
Jwallycars's Avatar
Smile 2007 fit acceleration problem
Nice job on my first post huh? Wow cannot believe I did that. My apologies. The year of my Fit is actually 2007. Thoughts on the acceleration problem?
Old Mar 9, 2016 | 04:06 PM
Jwallycars's Avatar
Hi there - I thought I would post back with my results. The coil pack closest to the serpentine belt was the answer to my acceleration issue. Yea!! Thanks for your help. Soon after (coincidence?) the service engine soon light came on. The error code that Autozone pulled up was P2647 pointing to oil level, or VTEC pressure switch.
I figure I should go to another thread to post this for ideas? Let me know your thoughts.
SilverEX15
32
May 20, 2020 08:22 PM
SilverEX15
Mar 1, 2017 04:56 PM
mandym22
Dec 17, 2014 02:47 PM
Shakey11
Jun 24, 2014 08:01 PM
Luke92115
Apr 25, 2011 09:21 PM
