Fowl odor
Old Jan 29, 2016 | 02:38 PM
413FitMurtz's Avatar
Fowl odor
Anyone else notice a burning type smell climbing hills? Mainly longer hills with accelerator pressed down more than half. Car is 15 ex 6spd
Old Jan 29, 2016 | 02:44 PM
Buck Fitty's Avatar
You may have a burnt clutch. Do you ride the clutch in city traffic? That can lead to clutch burnage. Have it checked before long; I think the warranty won't cover it.
Old Jan 29, 2016 | 02:48 PM
No I don't ride it. Car has 9k on it. Have noticed that the gears go in a little rough, always has
Old Jan 29, 2016 | 02:49 PM
Uncle Gary's Avatar
How many miles on your car? I noticed this the first couple of times I climbed a step hill back when the car was new. I assume it was paint burning off the exhaust manifold, since it went away after a week or so, and hasn't come back.
While I was typing this, I see you say you have 9K on the car. In that case, I haven't a clue. I haven't had this with my car since the first week I drove it.
Old Jan 29, 2016 | 02:52 PM
9000 miles
Old Jan 29, 2016 | 03:02 PM
CommanderSlug's Avatar
Could be a weaker pressure plate in the clutch assembly. I remember looking at the warranty package when sales were trying to sell me the extended warranty, and the clutch disk is not covered. But if I remember correctly, the pressure plate could be covered. Now, your issue occurs on longer ascents, right? Maybe a good idea would be to downshift a gear or two in those situations.
My clutch starts to smell when I powershift it from 1st gear into 2nd, but I do that very rarely, or when I drive hard combined with a few fast shifts.
Old Jan 29, 2016 | 04:15 PM
Buck Fitty's Avatar
If you don't ride the clutch, then it's likely that it's out of adjustment. Since glazing of the disk could mean replacement, and it's not covered by warranty, you should get it in the shop ASAP to verify that it's adjusted correctly ... before there's actual damage.
Old Jan 29, 2016 | 04:50 PM
Fit8175's Avatar
If it's a fowl odor - look for a bird in the grill.
If it's a foul odor - look for a mechanical issue.
Sorry, I couldn't resist.
Mike
Old Jan 30, 2016 | 07:38 AM
Carbuff2's Avatar
Could be the brand of gasoline you use. Or it could be the car ahead of you...
Try turning the intake air control to RECIRCULATE while going uphill...see if that makes a difference.
Old Jan 30, 2016 | 10:03 AM
1speedbike's Avatar
My manual had a defect from the factory. Hondas normally have incredibly smooth action so if you're shifting rough, I'd get the tranny looked at.
Old Feb 1, 2016 | 11:23 AM
GeorgeL's Avatar
Burning smells might simply be some part of the engine or exhaust that is running a bit warmer than usual, due to power loading or conditions. If it gets worse, worry. Otherwise it will likely go away.
I test-drove a Fit with single-digit mileage that smelled like an oil refinery. It was simply the preservative burning off of the exhaust manifold.
Old Feb 2, 2016 | 01:10 PM
Fitster C.'s Avatar
Like
Old Feb 4, 2016 | 01:14 PM
Fit_as_a_butchers_dog's Avatar
Do you get unduly nervous driving up hills? If so, you might want to tighten up your hygiene regimen. That might make it smell a bit sweeter in your car.
Old Feb 10, 2016 | 01:56 PM
Uncle Gary's Avatar
Fowl odor? Mmmmm, smells like chicken!
Old Feb 10, 2016 | 02:54 PM
u either slipped ur clutch or ur clutch is slipping... probably.
u shouldnt smell anything going up hill unless ure smelling fumes from cars in front of u.
Old Feb 11, 2016 | 08:39 AM
Uncle Gary's Avatar
Or you're smelling overheated brakes from trucks going down the hill in the other direction.
kgmcgrath
Jun 23, 2022 09:15 PM
bl00dtx
Dec 17, 2012 02:32 AM
tlenyc
Dec 12, 2012 02:46 PM
Carter303
Apr 25, 2011 05:34 PM
Fitcious
Sep 10, 2009 03:27 PM
