CVT Gearbox not moving
Old Feb 16, 2016 | 03:31 PM
ReadyF's Avatar
Hello
i got a very hard problem with my honda city (jazz) GD1 Year 2005
i have a automatic cvt gearbox
it move with no problem in Reverse mode
but when i switch to [D] and i release the brake the cars move forward
but when i try to to speed up the rpm moves up but the car doesn't move
any idea ??
Thank you
Old Feb 16, 2016 | 04:22 PM
dwtaylorpdx's Avatar
You have probably lost a solenoid/pressure valve in the tranny, reverse is usually a separate circuit so its still working. The shivs/pulleys relax in Neutral, a valve sets reverse then engages the pressure to the drive pulleys,, another valve just sets the pressure to the pulleys and away you go (NormallY) but in either case you likely need a dealer to plug in and run the diagnostics on the transmission. I don't think a generic machine will do it..
Good Luck.
Old Feb 16, 2016 | 04:26 PM
ReadyF's Avatar
Thank you for the answer
so is it that part that i have to change ??
Old Feb 16, 2016 | 04:28 PM
One of those actuators might be it, its a electronically controlled gadget so there is always a chance that its the ECU but I think the solenoids are cheap(er) you should only need 1..
Old Feb 16, 2016 | 04:33 PM
ReadyF's Avatar
i will try to inspect those parts
as there are no dealer in our country
Thank you
Old Feb 16, 2016 | 05:39 PM
If you can get a factory service manual on the transmission there should be a test procedure for testing the valve body. The question is if you can do it without a Nissan diagnostic computer.. Solenoids are usually tested with an Ohm meter, should have a specific resisters between the pins, and no connectivity between either pin and the body of the unit(Short) but I don't know if nissan grounds theirs though the transmission or through wiring..
Old Feb 16, 2016 | 06:37 PM
ReadyF's Avatar
Hello,
i think this is the procedure that you are talking about
i will try it tomorrow
CVT Drive Pulley Pressure Control Valve Test (CVT)
Thank You
Old Feb 16, 2016 | 07:03 PM
Thats where I'd start ,,, if its easily dismantled and you have it out of the car I'd definitely clean the passages in it with a nylon gun brush and some carb cleaner.. Blow it all out with air pre-lube with the CVT fluid and reassemble..
Old Feb 17, 2016 | 03:00 AM
ReadyF's Avatar
i have already cleaned the valve body ... but when i reassemble it i didn't put the cvt fluid, i have also noticed that there was a part of this valve body that it was supposed to have an in and out movement that was stick
Old Feb 17, 2016 | 03:02 PM
ReadyF's Avatar
Hello;
Here are photos from my engine bay !! which parts do you think i should inspect ?
Attached Thumbnails CVT Gearbox not moving-218231img20160217174742083.jpg   CVT Gearbox not moving-858161img20160217174735700hdr.jpg
Old Feb 18, 2016 | 02:35 PM
Make sure your getting good electrical connections everywhere and test the battery, if the battery is not producing full cranking amps, it may be low on kick to make the relatively high current solenoids trigger as they should. I had several weird little things on mine that a new battery definitely helped.
I haven't tore the fit apart yet I just work on lots of weird cars..
Old Feb 18, 2016 | 03:51 PM
ReadyF's Avatar
hahaha
Thank you for the reply;
i have changed the Driven Pulley Speed Sensor and nothing changed !!!
should i change also the drive pulley speed sensor ??
and how can i inspect those sensors ?
Thank you
Old Feb 18, 2016 | 05:51 PM
Hmm. You'd think it would throw a code on a bad sensor, I'm betting your not getting hydraulic pressure to the shivs, there is a diagram around here somewhere that shows the fluid map of the CVT that honda uses, that might help narrow down the possibilities cause you are only trying to troubleshoot forwards... Since it works in revers thee hydraulic pump "should" be fine. Thats why I suspect solenoids / valving thats misbehaving.
Old Feb 19, 2016 | 04:46 AM
ReadyF's Avatar
Could the problem be the Starting Clutch that is dead ?
or a bad sensor ?
this is a diagram that i found
and i will try to clean this
Attached Thumbnails CVT Gearbox not moving-123734saa2e02e15100000000caad09.png   CVT Gearbox not moving-157019saa2e02e15100000000caad12.png   CVT Gearbox not moving-581786diag.jpg   CVT Gearbox not moving-281230valve.jpg
Old Feb 19, 2016 | 06:19 PM
Not 100% sure, but I believe when they say "clutch: they are talking about the action of or the way the pulley starts the process of squeezing the belt/chain to start the car forward, its not a traditional clutch mechanism. Whats interesting is I don't see a reverse valve on that thing, Does the CVT use a aux transmission to change directions? Like a internal mini gearbox that puts a planetary in and out of gear, I haven't found a good exploded diagram of the Honda CVT yet.
Old Feb 20, 2016 | 02:10 AM
ReadyF's Avatar
Hello,
i think the best cvt description of the cvt of honda fit can be found in this page :
CVT System Description (CVT)
the sensor that i have changed yesterday was wrong, i have put a sensor of the civic.
i will also ispect the ignitions coils, maybe i have a misfiring problems
what do you think ?
Old May 29, 2018 | 02:58 PM
Tyingo's Avatar
Originally Posted by ReadyF
Hello
any idea ??
Thank you
hi there just read this , I'm facing the same issue right now . Was just wondering if you managed to sort yours out and if so , how ?
your help will be greatly appreciatedmissed
thank you
Old Mar 3, 2020 | 08:14 PM
Sattis's Avatar
Honda city 7 speed cvt, i got reverse but no drive HELP!!!
Hello
any idea ??
Thank you
Hi, I've the exact issue pls how can i solve this one, i just bought a new battery, alternator, gear oil, engine oil too and removed the valve body and cleaned it up but i am still not getting and positive result, what can i do?
Old Aug 4, 2022 | 03:56 PM
Junayj2's Avatar
Sa
Hi guys same issue with my Honda fit 2007 auto please help
kyawkyaw087
Nov 28, 2020 01:38 PM
teamjm
Jan 29, 2013 10:43 PM
dick29662
Oct 29, 2007 06:11 AM
