Continuously variable transmission (CVT) greabox problem on Honda Fit 2006 1.5S
Old Feb 18, 2016 | 01:09 PM
Giorgi Jaghmaidze's Avatar
Thumbs down Continuously variable transmission (CVT) greabox problem on Honda Fit 2006 1.5S
Hi,
Honda fit 1.5S CVT Gearbox has problem:
Sometimes, when in D (drive) gear, when I fully stop on traffic-lights and pull-off stop-pedal, car should start moving but sometimes "forgets" to drive for 1-3 seconds, during this time if I pull acceleration pedal, car will continue to be like N (neutral) gear, but actually it's in D (drive) gear, and suddenly gear-box hits hardly and car starts moving. what problem can it be? cause?
Old Feb 18, 2016 | 01:28 PM
dwtaylorpdx's Avatar
1. Check fluid!
2. Don't keep driving it that way, it is likely badly slipping the shivs.. (Excess wear)
3. Has it had the latest software recall stuff done?
4. Could be a bad/sticky control solenoid, part is not astronomical, labor might be at the dealer.. Unless its under warranty.
Old Feb 20, 2016 | 03:39 PM
Fluid already changed. No software warning.
Can it be caused by spark plugs?
Old Feb 29, 2016 | 01:13 PM
The Choobs's Avatar
It happens usually to CVT transmission after certain years. Tends to get worst during uphill climbs right. Check fluids.
The worst case scenario is your gears are slipping, which means you need to recondition your GB or have it checked. Happened to me once, cost a fortune.
Let's just hope yours is an easy fix.
LLLC1393
Sep 17, 2016 05:49 PM
DemoNikuA
Dec 3, 2013 07:35 AM
teamjm
Jan 29, 2013 10:43 PM
ROTORHEAD77
Aug 2, 2012 03:13 PM
agcat1981
Sep 14, 2010 04:45 AM
