Wider tires
Old Feb 26, 2016 | 05:05 PM
fitty bug's Avatar
Wider tires
I drive a 2016 honda fit lx. Is it possible to use wider tires using the original steel wheels? Currently, the tires are the original 185's. I am thinking of using 195's or 205's for all 4 tires. The reason I want wider tires is to get more traction on curves at high speeds. Any suggestions?
Old Feb 26, 2016 | 05:39 PM
dwtaylorpdx's Avatar
It will hurt your mileage and acceleration. Just keep the same size tire and go to a better tire.(Tirerack.com CONTINENTAL PROCONTACT TX or goodyear eagle LS,,, Examples...) Then do a Light suspension upgrade. Tokico or KYB / HP gas struts and shocks. Make sure you have a sway bar on both ends.
This should make it corner and keep the rolling resistance down so you keep your mileage.
Old Feb 26, 2016 | 06:01 PM
fitty bug's Avatar
Thank you dwtaylorpdx!!! I am a layman and don't know anything much about car modifications. I will take your advice and talk to a mechanic about it.
Old Feb 26, 2016 | 07:26 PM
While you can run wider, those wheels are narrow so the sidewalls will feel kinda mushy.
I was running 205/50/16's on my GE, but 7" width. It looked great and gripped very well.
Old Feb 26, 2016 | 07:59 PM
Just another thought to stir the pot a little, if you look at a formula V race car they are limited to tires that are < 6' wide. Have a 1200 CC air cooled bug motor, They only make about 50 HP. They turn some of the fastest laps on race circuits, if the driver is good. They are only seconds slower than cars with a couple hundred hp and 14" wide rubber. Its not "all" about width.. (They are on race tires.. ) Sometimes its momentum and skill..
Old Feb 26, 2016 | 08:07 PM
That's true but I think the op wants the wider look too?
max503
Aug 17, 2018 02:24 PM
Goobers
Jun 18, 2012 10:55 PM
ciburri
Mar 1, 2011 01:19 PM
fung88
For Sale - Local Pickup Only
Jan 31, 2010 05:03 PM
piperspost@webtv.net
May 10, 2005 11:42 AM
