Flashpro question.
Old Mar 7, 2016 | 05:55 PM
seeyalaterbye's Avatar
Flashpro question.
Is a flashpro all that's needed ECU wise to go turbo? I keep reading a AEM harness is needed but I believe that was for before the flashpro came out.
This is on a 08 gd3 BTW.
Thanks for the help.
Old Mar 8, 2016 | 02:21 PM
cnordt24's Avatar
That's actually a really good question, I've got a flashpro and Ive read the same thing about needing an AEM harness for turbo.. I would think the flashpro would do the AEM harness's job
Old Mar 9, 2016 | 03:06 PM
TPColgett's Avatar
Why would you need an AEM harness? You would need a harness to run an AEM FIc or other piggy back sure. If you are reading all the old turbo GD threads on here, you will see that is what they did to run the AEM FIc.
BUT
The FlashPro completely replaces any need to run a piggyback tuning unit and is FAR more capable.
You will still need a laundry list of other components to do an turbo setup, but as far as tuning, the FlashPro will support just about anything inside of most peoples goals.
Old Mar 14, 2016 | 03:37 AM
DWils's Avatar
Correct. FlashPro is an acceptable tuning device for the GD3s. Turbo'd or not. KTuner will eventually work on supporting the GD3, but as of now I do not believe it is supported.
Old Aug 19, 2016 | 03:02 PM
876fit's Avatar
does anyone know if this will work on a jdm fit?
fittenmittens
Oct 2, 2017 07:35 PM
Midnightfit
May 26, 2010 12:29 PM
NIGHTHAWKSI
Mar 31, 2010 08:13 AM
NotraFit
Dec 22, 2009 03:56 AM
pbz08gd3
Sep 8, 2009 03:41 PM
