Air conditioner stinks, need evaporator diagram?
Old Mar 11, 2016 | 09:47 AM
vonBobo's Avatar
Hi all! So my AC stinks, and from the limited amount of information it seems as though I probably have mold/mildew in my evaporator box (is that the correct term?).
I would like to open it up and clean out everything, check the drain hose to make sure it isn't clogged, and then start a maintenance schedule of using the fungicides you can spray into the dash vents to help keep it from recurring. Problem is, I don't know how to go about doing this. Is this an "easy" job? Anyone know of a diagram?
Thanks!
Jeff
Old Mar 11, 2016 | 04:02 PM
dwtaylorpdx's Avatar
Its possible that if you remove the HVAC/Climate air filter you can see in there.. With a mirror? Its pretty easy to get to..
White vinegar kills mold and once it dries out the smell goes away.. (About 1 part vinegar 2 to 3 parts water.. )
Old Aug 9, 2016 | 01:52 PM
dll932's Avatar
I periodically spray Lysol in the cowl vents with A/C running full on recirc, shut it off a minute, then restart the fan with the doors open.
Old Aug 20, 2016 | 03:50 PM
Yagi13's Avatar
cabin air filter
It might be helpful to clean or replace the cabin air filter after you check it out, sometimes they can become musty
Old Aug 22, 2016 | 08:48 PM
Alco RS-1's Avatar
To avoid this from reoccurring, I usually turn off the A/C a block from the house, but leave the fan on. This blows outside air through the (inactive) evaporator and helps to dry it out before I shut the engine off.
Old Aug 22, 2016 | 09:37 PM
Vash's Avatar
mine stinked too, especially when i used a cheap air filter.
however this is a good one that doesn't stink! https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
it doesn't stink!! but when you first use it a bunch of white powder might come out of your vents so watch out! don't point it towards your face.
lesterlai12
Aug 17, 2022 06:41 PM
henryd1981
39
Jun 6, 2017 11:09 AM
Brain Champagne
Dec 31, 2012 12:10 AM
0Dang
Aug 18, 2011 11:40 AM
2K8SPORT
Jul 29, 2008 05:30 PM
