T vs H speed rating. What do you have?
Old Apr 19, 2016 | 08:33 PM
littleblackcar's Avatar
I want an H speed rating in 175/65R15. Do you care whether you have T or H?
Old Apr 19, 2016 | 09:37 PM
DrewE's Avatar
I don't care in the least. I don't believe I will ever exceed 118 mph with my Fit, nor likely two-thirds that velocity.
Old Apr 20, 2016 | 11:03 AM
Fit Charlie's Avatar
If you're going to spend hours at a speed high enough to put so much heat into your tires that they fail, getting tires with the right speed rating won't solve your real problem: that you bought the wrong car.
I don't know what speed rating my tires are. Never have.
Old May 2, 2016 | 10:06 PM
The sticker inside the door actually recommends an S rating. I don't even think those are available! (Nor would I want them.)
Old May 5, 2016 | 11:38 PM
gallent92's Avatar
I usually don't care about speed ratings but more on load ratings of these tires. TireRack a good information on load and speed rating:
Tire Tech Information - How to Read Speed Rating, Load Index & Service Descriptions
Old May 7, 2016 | 11:31 PM
Rollerboots666's Avatar
Yeah older Fit's were "S" rated unless you had a sport which are "H". I highly recommend go with the higher speed rating like H.
Old May 8, 2016 | 10:19 AM
fujisawa's Avatar
Do you think you will go over 100mph? I tried .. Once. I don't think the poor L15 has much more to give after that! If you happened to live in one of the few areas people drive 85 frequently, sure good idea, but I think at that stage you might really appreciate a more stable car. German car or Ford probably. I don't think the design requirements for a Fit have top speed at the top of them ...
Old May 8, 2016 | 04:24 PM
Speed rating has an effect on the tires' handling, even at lower speeds. No, I won't go 100 mph, but that doesn't matter. In the original size for a 2011 Base, there are around three options only. Avid Ascends, Toyo Versado Eco (T rating), and General Altimax HP. Mochelin no longer makes the Pilot Sport A/S in 175/65R15.
Not many choices....
Old May 8, 2016 | 11:07 PM
Odie's Avatar
H likely to give a little better handling when cornering . We use GENERAL Altimax RT43 for both '11 + '13 . They are 175/65-15 , H-rated , A.A. Can be purchased for under $75 each ( before tax ) . I think there's a $50 rebate this September . Can be ordered through Wal-Mart .
Old May 8, 2016 | 11:31 PM
How do you like those Generals? Have they worked well in rain and snow, and on long trips?
Old May 9, 2016 | 11:00 PM
Odie's Avatar
Like them well enough for use of both cars . They did good on packed snow / icey road we live on . They do quite well in rain / wet roads . Would use other car when snow , ice or mix present or in the forecast . They both ride better too . Feels like different vehicle . The long run will tell . Keep them at 35 > 37 p.s.i..
colliewagon
May 6, 2010 09:11 PM
billmus86
Car Shows, Events, and Racing
59
Dec 26, 2008 09:29 PM
bigmac
Mar 31, 2007 10:24 PM
Keep Fit
May 18, 2006 01:02 PM
Lalala218
May 17, 2006 08:01 PM
