Whistling sound at cruising speed
Old May 11, 2016 | 11:48 AM
thinhdle's Avatar
I just got my 2016 EX last week. I started to notice a high pitch sound not to loud at cruising speed between 40-50 MPH. it goes away at high speed and idle. Anyone else notice that?
I normally hear it during city driving but not highway which is at higher speed.
Thanks
Old May 11, 2016 | 02:56 PM
2Rismo2's Avatar
Only whistling I hear is when I have the moon roof open and the air going by the wind deflector. If I reach up and pull the deflector down it goes away.
Old May 11, 2016 | 03:09 PM
thinhdle's Avatar
Thanks but my moon roof is not opened. I can hear a faint whining sound at certain speed. I think it could be the CVT transmission.
I did some research I found many people with Honda CRV are complaining about the similar issue but Honda does not have an answer for it.
The squeal or whine is nothing but a minor annoyance so I'm going keep driving for a while longer to see what will happen.
My car has only 1000 miles so maybe it will goes away after a while.
Old May 12, 2016 | 12:56 PM
dwtaylorpdx's Avatar
If you google how CVT transmission works you'll see why cat's tend to make some noise, between the hydraulics and the "belt" between the shivs there are several varying contact points that depend on friction for the tranny to do its job..
FWIW my Polaris quad makes ton of noise at low speed.. Similar function to the honda CVT..
Old Jan 14, 2018 | 10:04 PM
HarleyBadger's Avatar
My '16 CVT has always done it, never been a problem. It's simply a hydraulic pump noise from what I've been told (friend who is a Honda mechanic in Atlanta)
Old Jan 14, 2018 | 10:49 PM
bargainguy's Avatar
I noticed a similar sound on my 2016 LX a couple times, kind of annoying when it happened although very infrequent, seemed to be coming from the driver's front door. My guess is that it's the rubber door surround getting buffeted by certain combinations of wind, angle & vehicle speed.
Old Oct 17, 2020 | 01:54 PM
pittpanther's Avatar
I have the same whistling sound with the moonroof open - either tilted or slid back - on our 2020 EX-L Fit as well. Thinking of adding the moonroof visor to mitigate.
Old Oct 17, 2020 | 06:34 PM
Fuelish's Avatar
Have never noticed on our '15 LX with a manual trans, but...due to gearing, engine is revving high at hwy speeds, like 2500@50mph, 3500@70mph...n0t a quiet car, but, am fine with it, heck I'm half deaf already
Old Oct 18, 2020 | 08:53 AM
TnTkr's Avatar
I can recognize similar noise on my 2019 manual Jazz. It is most annoying at 50-55 mph and it goes off if I lift my foot off from the accelerator pedal.
Old Oct 20, 2020 | 11:01 AM
I did wind up ordering the Moonroof Visor from Bernardi. Will report back once installed (hopefully this weekend). Not a big fan of the look of the visor, but the whistling is driving me insane.
Old Oct 26, 2020 | 09:28 AM
Jazu's Avatar
Does the whine increase in pitch as the car is driven faster or if you drive the same speed (and shift into Sport) is the whine different at different RPMs
Old Oct 27, 2020 | 06:01 AM
Action Jackson's Avatar
Someone here mentioned that the windnoise is worse with the oem moonroof visor, hence I passed on it. If it isn't too bad I might consider it.
Yeahhhok
Jun 21, 2018 12:31 AM
geepondy
Jan 20, 2018 11:06 AM
sneefy
Aug 18, 2017 02:22 PM
shawnshank
Jun 12, 2016 09:12 PM
sonicfox
Jun 9, 2015 08:32 AM
