Door Sensor bad?
Old Jul 28, 2016 | 01:09 AM
fritz269's Avatar
Door Sensor bad?
Like it said, I check all the doors and they all seem closed. When I drive the like tells me that the door is open..well it kinda flickers. The wierd thing is that the automatic door lock and unlock works great when its like this but the if the light does not flicker(rarely) the door auto door unlock does not work as it should. Anyway to check it myself or do I have to take to the dealer?
Old Jul 29, 2016 | 02:59 AM
gallent92's Avatar
Howdy! What year of your Fit? Better to take it to the dealer.
Old Jul 29, 2016 | 03:02 AM
fritz269's Avatar
2009. Well I guess ill have too
Old Jul 29, 2016 | 04:49 AM
Michael M Perez's Avatar
Locking Problem
It could be because the key fob battery is dead or faulty. Check if the fuse is blown or if the solenoid is bad. One another reason could be if the wire is broken
Old Jul 29, 2016 | 05:23 AM
n9cv's Avatar
If it is intermittent, the dealer is not going to find it and you will have a big bill. Odds are it is a defective door switch. I would disconnect the driver's side door switch for a while and see if the problem goes away. If it does, go get and replace the door switch.
If the problem is still there then try the same thing on the other doors one at a time.
Old Jul 30, 2016 | 07:23 PM
fritz269's Avatar
Thanks. I'll try that.
~Lesly~
Jul 9, 2019 11:36 AM
plastidip
Jun 26, 2017 01:51 PM
markakis3100
Mar 25, 2016 01:50 PM
minchoww
Oct 24, 2011 10:31 AM
wootang00
Oct 5, 2009 01:17 AM
