Fit I.C.E. Threads discussing in-car electronics including audio, video, security, and navigation systems for the Honda Fit/Jazz
Neg/Pos wiring no difference, help please
Old Nov 28, 2016 | 10:45 PM
spootnik's Avatar
Ok,
Over the weekend i installed a pair of JBL GTO638 in the front. Installation was fairly easy and all.
Then came the time to do wiring, i wasn't sure which colour is negative and positive. So, i thought i'd try and listen because "they" if you get the wiring wrong the speakers will sound like horrible.
I spent almost 20mins swapping wires back and forth and i could not hear any difference in the sound at all. I even made sure to swap it as quick as possible a few times during a "note" to get the same vibes and identical, no matter which wire i swapped around.
I am quite puzzled, can anyone explain why ?. Both left and right i spent a good half hour swapping testing and could not hear a difference. I even asked my boy to listen and tell me if there is a difference and he was like "mehhh" it's same.
Old Nov 29, 2016 | 12:46 AM
ezone's Avatar
In a typical install, a decently loud hard bass note should make the speaker cone push outward. If yours pulls the cone inward on a bass note, it's wired backwards.
I have a 2011 USA wiring diagram (not sure how similar your car will be) that shows
LF door speaker :
Light blue +
light green -
RF door speaker:
brown +
red -
Old Nov 29, 2016 | 03:16 PM
spootnik's Avatar
LF door speaker :
Light blue +
light green -
RF door speaker:
brown +
red -
Haa, the wiring colour is right, yep. Any chance you can also tell me about the rear wiring colours please and thanks ?.
Ok i will re open the door and make sure the wires are as specified above, thanks again for this info
Old Nov 29, 2016 | 03:24 PM
ezone's Avatar
LR
Gray +
Brown -
RR
Blue +
orange -
Look on the stock speakers, one of the terminals might actually be labeled
Old Nov 29, 2016 | 06:19 PM
spootnik's Avatar
LR
Gray +
Brown -
RR
Blue +
orange -
Thanks a lot for this
I did look at the oem speakers but didn't see anything on there, maybe i didn't look close and long enough.
Old Nov 29, 2016 | 09:56 PM
Brain Champagne's Avatar
There's no positive and negative on speakers. Audio is AC, not DC.
The issue is that if you have polarity reversed then the bass will sound weaker. Because bass is less directional, if the speakers are out of phase, the bass from the left and right will cancel each other.
So it doesn't matter how they're hooked up except if it sounds like the bass is weaker, reverse the pair on ONE speaker.
Old Nov 29, 2016 | 10:02 PM
ezone's Avatar
Old Nov 30, 2016 | 05:17 PM
spootnik's Avatar
Ahhh this explains a lot
Old Dec 2, 2016 | 05:42 PM
spootnik's Avatar
So, today i got around to checking those wires. Opened my doors and unscrewed to find it was all nicely wired
Instinct haha, ah well. Waiting for my other two speakers to come and ill do the rears.
Thanks again
rickame
Nov 27, 2016 10:24 AM
c.jansson
Nov 24, 2016 08:55 AM
klilja
Fit I.C.E.
Mar 30, 2014 10:28 PM
BStecke
Feb 7, 2011 06:07 AM
TheZombie
Oct 3, 2010 03:27 PM
