misfire & hesitation when acceleration
Old Jan 3, 2017 | 08:55 PM
Hondarian's Avatar
I have problem after changing coil Plug & spark plug, I'm check on obd Scan, STFT & LTFT engine running rich, but o2 sensor determine my engine running lean, MAP, IAT, Coolant Sensor, TPS, vacuum leak is checked and in good condition, I suspect o2 sensor is bad/clogged because only show 0.1volt
Short term fuel trim bank 1 , long term fuel trim bank 1, long term fuel trim bank 2, intake tempreture,
O2 bank 1 sensor 1 show 0.1 v even intake is open
Attached Thumbnails misfire & hesitation when acceleration-1-80-screenshot_2017_01_02_15_07_51_483_org_prowl_torquefree_091d84312cfb3e657cb04a6440d7dd5437d.png   misfire & hesitation when acceleration-2-80-screenshot_2017_01_02_15_08_20_325_org_prowl_torquefree_5eac149d3f052f1bf86af7067e5cbf48cba.png
Old Jan 6, 2017 | 09:37 PM
doctor J's Avatar
Did you use Honda parts from reputable source?
If so, check the new spark plugs for proper gaps and proper tightening.
Denso plugs have "hard to crush" sealing washer; semi-tightened plug may leak and cause misfires
Old Jan 9, 2017 | 08:08 PM
Hondarian's Avatar
Im using 4 new hitachi coil, im disconnect all 4 coil connector when engine is idle, i feel a reduction in engine rpm, it happen after changing a coil
henryweston157
18
Apr 4, 2019 07:24 PM
benjhind
May 23, 2018 03:20 PM
Body2Big
Mar 5, 2016 11:54 PM
Jeff Pirkey
Aug 13, 2011 12:14 AM
Santiad
Jul 21, 2011 04:46 PM
