leaking reservoir tank
Old Jan 10, 2017 | 07:19 PM
mat77's Avatar
hi, my jazz leaking coolant from reservoir tank, engine temperature hot, already replace thermostat, radiator cap, and water pump.... the odd thing is when drive downhill temperatur become normal..... any idea?
Old Jan 11, 2017 | 10:30 AM
Jeema's Avatar
Your engine is under less load when going downhill, so that may be why the temperature decreases when going downhill.
There's any number of reasons why the car could be overheating. The most common is probably the thermostat.
You said you replaced it, but with what brand? Honda or aftermarket? Aftermarket ones can sometimes cause problems because they don't always meet the necessary specifications...
Old Jan 11, 2017 | 06:12 PM
mat77's Avatar
thermostat orignal honda
Old Jan 11, 2017 | 06:29 PM
solbrothers's Avatar
did you put it in backwards?
Old Jan 11, 2017 | 07:08 PM
mat77's Avatar
we install in correct position, same position from the old one.
mat77
Jan 12, 2017 09:48 AM
Bugzs15
Nov 5, 2013 06:57 PM
wzard999
Oct 15, 2013 10:48 PM
Crisu
Mar 16, 2013 05:12 PM
Fijoy George
Aug 10, 2005 12:20 PM
