Something Stuck In Aux Jack
Old Jan 29, 2017 | 07:16 PM
Jacob Faria's Avatar
Hi all,
I'm looking at buying a 2010 Fit and noticed during the test drive that the 3.5mm jack has something stuck in it. (Picture will be added in post below.) From looking at the manual, it seems to be the cover that comes with the car, broken off.
Regardless, I'm looking for advice on if this can be removed (would need to be from inside) and if it can be, could the jack itself be replaced if it were broken?
If if it can't be fixed, can anyone advise on how expensive/difficult swapping in an aftermarket head unit is? (yes, I'll search as soon as I post this as well )
Any advice is appreciated.
Thank you!
Old Jan 29, 2017 | 08:49 PM
degnaw's Avatar
My stock radio is sitting in my room and it doesn't look like there's any way to access the back. The headphone jack is part of a large circuit board that contains the rest of the buttons, so you'd likely have to replace the whole radio if you can't pry it out from the front.
As for aftermarket options, you can get a dash kit for ~$17 and all necessary wiring harnesses for <$10, and it's pretty straightforward.
Old Jan 29, 2017 | 09:01 PM
Dean's Avatar
SilverEX15
Sep 26, 2017 08:55 PM
trashercan
Sep 24, 2017 05:46 PM
dstahnke
May 3, 2012 10:14 PM
secondspassed
Dec 28, 2009 04:50 PM
mozarwasagenius
Apr 22, 2009 10:10 AM
