oil leak around the flywheel cover
Old Apr 20, 2017 | 09:39 PM
1fit2fit's Avatar
I just spotted an oil or clutch fluid leak showing around the bottom of the bell housing by the flywheel cover. photos included. the clutch seems to work well although I've often thought in the 2 monthjs of ownership that it should have firmer pressure. The flywheel itself looks clean. I cleaned the entire area and will check again soon to get a better idea of where it's coming from as there was alot of gunk buildup. prettysure it was coming from inside the bell housing. Any ideas?
Attached Thumbnails oil leak around the flywheel cover-img_4131.jpg   oil leak around the flywheel cover-img_4137.jpg
Old Apr 21, 2017 | 10:01 AM
Carbuff2's Avatar
Rear main seal? Replace the PVC valve. If stuck, crankcase pressure will relive itself SOMEWHERE.
Old Apr 21, 2017 | 10:34 AM
1fit2fit's Avatar
the last person to change oil had overfilled it about half a quart above the top fill mark on the dipstick. could an extra half quart caused enough crankcase pressure to cause a rear main seal to leak. also, once it starts leaking, is it done and needing replaced? I will check the pcv valve and that system as well. I did drain the extra oil out and now have it at about 1/2 to 3/4 in between the marks on the dipstick. thanks
Old Apr 21, 2017 | 01:57 PM
Carbuff2's Avatar
Was oil dripping on the ground? If not don't bother yet...the labor cost will be a lot higher than the cost of a drip.
If you are ever in there for a clutch or something, that's the time to replace it.
Scotty2h
Aug 27, 2015 06:19 PM
fhoeft
Oct 19, 2012 01:11 AM
FELIXY69
20
Mar 26, 2011 01:36 PM
Buktheng
May 17, 2008 10:44 AM
sonicsc1
May 10, 2008 08:32 PM
