Misfire p0303 p0301 p300 HELP
Old Apr 28, 2017 | 02:11 AM
Mrb4lyf1269's Avatar
I recently had a misfire in cylinder 3 and got it fixed with new coil and plug. A couple days pass and a o2 sensor goes out and I replaced it. Now I have all these codes popping up. Replaced all plugs and coils. Problem still persist. When car warms up the idle becomes real rough almost cutting out..start to drive and the top of 1st is good, 2nd is good, 3rd gear is ok takes a little while to get to 4th. 4th gear is a little rough when getting to 5th and at low rpms is rough. Got a innova scanner and seen that the egr comm was at 0 and egr error was 99.2 so I cleaned it up and the passage way now they both are reading 0. Not sure what else to do. Here is the freeze frame from one of the error codes.
fuel sys 1 CL
Fuel Sys 2 NA
Calc Load(%) 32.5
ECT(F) 170.6
STFT B1(%) -6.3
LTFT B1(%) 0.0
MAP(inHg) 9.2
Eng RPM 1706
Veh Speed (MPH) 0
Spark Adv() 19.0
IAT(F) 89.6
TPS(%) 16.1
Run Time(sec) 11
Comm EGR 0
EGR Error(%) 0.0
Command EVAP 0.0
Fuel Level% 84.7
BARO(inHg) 29.2
ECU Volts 14.4
Load Value% 31
EQ Ratio .999
Rel TPS(%) 5.5
TPS B(%) 32.9
ACC Pedal D(%) 27.1
ACC Pedal E(%) 5.9
Command TAC(%) 5.9
angus.mundy
Dec 15, 2024 12:16 AM
henryweston157
18
Apr 4, 2019 07:24 PM
Mrb4lyf1269
Apr 28, 2017 02:12 AM
nielmot
Mar 2, 2017 07:54 PM
CTCT
Nov 26, 2012 10:00 PM
