2007 Fit Hatchback Lock
Old Jun 18, 2017 | 05:23 PM
ktbishop222's Avatar
I have an 07 Fit with a hatchback that no longer locks/unlocks when I hit the lock/unlock buttons on the key fob. The front and rear doors work fine, but I now have to reach through the back and poke a finger through the little hole in the panel to lock and unlock the hatch since it doesn't have a key hole. I've listened in the panel for any noise when unlocking and locking, but there's no noise. I'm ready to just replace the actuator since they're pretty cheap, but I thought I'd check here to see if anyone else has any ideas before I do that. Is there a separate fuse or anything for the hatchback door lock? I can't seem to find a decent diagram of the fuses.
Old Jun 19, 2017 | 12:05 AM
Sono's Avatar
Check for power to the motor, if no power trace it back ( check fuses, connections ) if there is power at the plug then its the motor.
Old Jun 19, 2017 | 08:01 AM
Do you know if there are separate fuses for the front/rear doors vs the hatch? When I bought the car used it came with a 2010 owners manual () and I haven't been able to find that information anywhere.
Old Jun 19, 2017 | 09:18 AM
Sono's Avatar
No I don't sorry as I'm new to the Fit's, Had my 2008 for a month now. Check for power at the motor connection and trace it back from there, the wiring should pass through a loom from the hatch to the body at top somewhere ( can be a breaking point in wiring due to movement and other issues ) check for any broken wires there. I don't know the wiring color codes to check from the fuse block or anything in that general area as I don't have a repair manual ($17 at autopart stores) which I usually buy when I get a car that needs work that I haven't purchased yet for the Fit. Hopefully someone else might know and chime in, I will search online a bit today to see if I can help further.
Old Jun 19, 2017 | 09:25 AM
Sono's Avatar
But first, get a test light on it and see if it flashes when you lock/unlock the doors, that will weed out power or actuator issues
Old Jun 29, 2017 | 01:44 AM
DraloreShimare's Avatar
All the lock actuators are on the same fuse (#28 according to my manual). If you're not hearing the actuator click back and forth, it's either the actuator itself, or wiring. And of those, it's more likely to be the actuator.
Old Jun 30, 2017 | 08:42 AM
Thanks for the info. I've been traveling for work since I posted this, so I haven't had any time to mess with it. I'll probably just get a new actuator and swap that out when I'm home again.
Old Jul 1, 2017 | 08:34 AM
Carbuff2's Avatar
You are well-advised to lubricate the manual lock mechanism too. If the handle binds the door might not release.
I squirt some oil in the outside handle pivots every oil change, since ours bound up after 7 years of use.
jjrbus
Sep 7, 2022 04:12 PM
dhoran
Sep 29, 2020 09:28 PM
arkansasfit
Sep 15, 2019 04:37 AM
Eric Moss
Feb 19, 2015 06:58 PM
DaveFL
Feb 12, 2014 05:26 AM
