2007 Fit mileage drop
Old Jul 3, 2017 | 03:59 PM
Sean McKenzie-Mardelli's Avatar
My 2007 Honda Fit has recently seen a drop in mileage... I used to get 620km (387mi) per tank in summer at 90km/h (56mph) but now I get about 560km (350mi) under the same conditions. I have fresh oil, new air filter, new spark plugs and coil packs. Can anyone recommend other things to check as a possible cause for this? Driving style has been kept constant.
Old Jul 3, 2017 | 05:24 PM
JockoT's Avatar
Check tyre pressures and, after driving, check you do not have a hot wheel. That could indicate a brake rubbing.
Old Jul 4, 2017 | 08:07 AM
Carbuff2's Avatar
Check valve clearance, too. Do it NOW before you burn a valve.
Our Fit w 135K miles on it, just achieved 39 MPG on a 250 mile trip. <---incentive
Old Jul 4, 2017 | 06:58 PM
Tires 36psi all around. No seized calipers or rubbing brakes
Old Jul 4, 2017 | 07:01 PM
Hmmmm according to the owner's manual I should have done this 2-3 years ago but when I brought it to the shop they said there's no point. Also doesn't it cost $600-$1000 to do this? I'll have to read up on this issue
Old Jul 4, 2017 | 07:59 PM
Carbuff2's Avatar
The valves in the 1.5L engines DO require periodic adjustment.
I've done ours myself every 60K miles and several were out-of-spec each time.
It took me 2 - 3 hrs each time, but I'm an amateur. An independent Honda specialist could do it for you for a LOT less than a dealer.
Old Jul 4, 2017 | 08:22 PM
When I paid an independent shop to do a valve adjustment on both my S2000 & my ex-wife's Fit, it was around $200 per car.
stridermxli
May 12, 2016 03:16 PM
hollyh
Mar 11, 2016 10:43 PM
gkitf16
Sep 7, 2014 11:58 AM
richardwhite
Sep 4, 2014 09:43 PM
throwawaysearching
Oct 18, 2009 09:59 PM
