Car won't start
Old Aug 1, 2017 | 03:17 PM
Philip May's Avatar
Car won't start
My 07 Fit won't start! I turn the key and get a single click. It used to start intermittently, I'd turn the key, nothing, let it sit for awhile m it starts right up. Problem has been getting more frequent in the coming weeks until now, it will not start at all. It is not anything electrical (radio, dash lights, everything works) I get a "single click" when I turn the key. When it did this before, I'd turn it off, pull the key out and try starting it again and it would start, now it doesn't! Jumping has absolutely no effect! Also, the battery is about a year old. Car runs fine after it starts.
Old Aug 1, 2017 | 04:04 PM
AnalogDog's Avatar
Sounds like the starter solenoid is bad.
Old Aug 1, 2017 | 05:47 PM
or clutch/brake switch
Old Aug 2, 2017 | 12:37 PM
n9cv's Avatar
Sounds line starter solenoid or starter itself. Could also be a bad connection of the heavy cable on the starter.
Old Aug 3, 2017 | 07:55 PM
doctor J's Avatar
Most likely starter solenoid contacts. Tap the starter (easy said than done) and see if it starts
Old Aug 8, 2017 | 02:29 AM
CanyonRcr's Avatar
I have the same problem. Battery terminal was loose. Also battery is smaller than it was recommended. Replaced the battery and tightened the battery terminal. Problem solved.
Rikkie Her
May 19, 2019 05:46 PM
Rrff1954
Aug 9, 2018 06:52 AM
wzlfit
Mar 30, 2016 07:52 PM
manbat39
Aug 4, 2005 05:30 AM
mmdir2002@yahoo.co.uk
May 4, 2005 11:16 AM
