Installing Dash Cam in a 2017 EX?
Old Sep 17, 2017 | 09:03 AM
RavenManiac's Avatar
I'm getting ready to install a front/rear dash cam in my son's 2017 Honda Fit EX next weekend. He, and the car, are away at college. My plan is to pull power from the interior fusebox using two low profile fusetaps.
  • Where is the interior fuse box located?
  • Which circuit can I pull constant 12V power from?
  • Which circuit can I pull accessory switched 12V power from?
  • Is it better to run the rear camera wiring along the rocker panel or above the headliner? Not sure what obstacles need to be avoided.
Any help or advice is greatly appreciated.
Old Sep 17, 2017 | 11:27 AM
2Rismo2's Avatar
When I had the rear camera, I ran it along the headliner and it was pretty easy. The camera was mounted on the plastic cover for the middle seatbelt.
Old Sep 17, 2017 | 11:37 AM
camera might get unwanted attention while parked at college or apartment.. just something to think about i guess. last thing you need is broken glass.. and you know college is a pretty crazy place when alcohol is involved.
as for the fuse box, it's on the left side of the steering column above the tpms switch.
Old Sep 17, 2017 | 11:56 AM
He lives about 5 miles from campus in a private apartment complex that has 24-hour video surveillance. Plus, there are at least 3 police officers who reside there as well, so I think he's good.
Old Sep 17, 2017 | 02:58 PM
sounds good. i guess he never goes out to parties and bars/restaurants in his ride.
Old Sep 17, 2017 | 03:19 PM
The Fitness's Avatar
Old Sep 17, 2017 | 05:53 PM
Action Jackson's Avatar
I put my rear camera on the inside of the car facing backwards. That way the camera will be able to see almost all of the rear side windows, and part of the front sides too.
Old Sep 18, 2017 | 01:15 AM
That's an interesting idea. Do you have any photos or rear dash cam video links?
Old Sep 18, 2017 | 01:20 AM
No he doesn't. He's a recovering addict and goes to NA meetings every night. He does occasionally go to parties, but they're usually in state parks or another members home.
Old Sep 19, 2017 | 08:05 AM
i wasnt expecting a serious reply, but good to hear ur son is on the road to recovery.
were you able to find the fuse box on the left of the steering column above the tpms button? those cameras dont pull much power so any switched fuse 10A or below should be plenty. add-a-circuit's max is 10A for the fuse you are tapping into so dont want to go too high.
honestly for my radar detectors and low amp LED's and stuff, i dont even use add-a-circuit and just cleanly wrap the wire on the terminal of the fuse and push it into the fuse box. i crimp a 5A fuse inline, wrap it with e-tape, zip tie the wire to another wire or bracket so it dont pull out, and walla.
Old Sep 19, 2017 | 08:36 AM
No worries. No, I haven't located the fuse box yet, because he won't he here until this coming weekend so I don't have access to the car–yet. Yes, I'm using a fuse tap with a 5A fuse.
Old Sep 22, 2017 | 08:37 PM
Old Sep 22, 2017 | 11:13 PM
Nice. Thanks for posting the images.
paul_g
Feb 16, 2019 04:37 PM
silentpoet
Apr 17, 2018 10:46 PM
RavenManiac
Dec 28, 2017 12:58 PM
RavenManiac
Jun 18, 2017 01:41 AM
jeuda
Nov 17, 2013 06:44 PM
