Suspension Clunk - Strut Mount?
Old Oct 31, 2017 | 01:38 PM
skiboarder119's Avatar
At slow speeds over bumps I hear a clunking from my suspension. It is definitely the front and seems to be both the right and the left. Stabilizer links are secure and not worn out. Bouncing the car by hand doesn't not produce the noise. Dampers are still working correctly. Ball joints and bushings on the lower control arm are secure and have no free play. Steering knuckle is secure and has no free plate.
The last thing (which I can't rule out without disassembly) is the strut mount bushing is probably worn out. Does anyone have experience with these failing? Does this make sense to the community on here?
I did a lot of searching and most people talked about stabilizer links. I was hoping to make one dedicated to failures of strut mount bushings.
I'd rather not spend $ before I know what it is (this is just my winter beater). I'd also rather not tear my whole front suspension apart and then have to drive my sports car on the roads now covered in Salt.
Thanks for your help,
Old Nov 1, 2017 | 05:09 AM
doctor J's Avatar
When the driver side end link failed on my car, I reproduced noise by opening drivers door and shaking car sideways by pulling down on the door; also it was an old mattress noise when I was getting on the seat.
Old Nov 1, 2017 | 08:52 AM
Carbuff2's Avatar
It's been my experience that you can't tell a noisy sway bar link by a visual inspection. You just need to replace 'em.
If you are truly money-adverse :-) you could try injecting grease into the rubber boots on the links via a needle attachment on a grease gun. See if that changes the noise.
Old Nov 7, 2017 | 12:21 PM
My experience you can always tell bad ball joints and bushings by wiggling them.
After a second inspection, I found the lower drivers sway bar link was indeed loose (worn out). I just had to pull a little harder (by hand) on it and listen a little closer.
I replaced it last night, car sounds great this morning.
I do not recommend people pull up on the end of the door as mentioned above, as a designer of hinges and doors like this, I can tell you it is not meant to handle this sort of loading. You could bend your hings or the sheet metal hing mounts. If you must get more force on the link you can pry between the sway bar end and the subframe mounting location fairly easily.
Old Jan 14, 2020 | 08:17 PM
ChrisA70's Avatar
Replaced my end links, and the front end still sounds like bad strut mounts... Dealer says this is a normal sound for the Fit. I'm ready to replace both struts with KYB, new rubber mounts, strut bearings, etc. The noise irritates the crap out of me, and if it is a normal thing for the weird designed way these struts are in these cars, I will trade it in in a year or so.... My CRV(2008) has 150k on original struts and feels like a cadillac compared to the 16 Fit. No noise at all.
Old Jan 15, 2020 | 07:39 AM
doctor J's Avatar
Talking
Nonsense!
It's about swings or old baby stroller!
While door skin is extremely easy to damage the door frame, hinges and A-pillar can withstand mush greater force without damage.
Old Jan 15, 2020 | 11:15 PM
eulogy's Avatar
have you inspected the welds under the cowl?
Old Jun 12, 2022 | 12:39 AM
mailnitram's Avatar
did you ever figure it out I got the same thing going on
Old Jun 12, 2022 | 06:13 AM
ChrisA70's Avatar
Well, after arguing with the useless dealer I bought it from I decided to order new KYB struts, and all new genuine OEM top parts and replaced them myself. The clunk went away completely. It was like a new car. I traded the 16' Fit in last year on a 16' CRV(mistake) I wish I had it still. Now I have a 2018 Pilot lol.
Old Jun 12, 2022 | 10:23 PM
mailnitram's Avatar
just swapped in new strut assembly clunk is gone finallllyyy!!!! It really does feel like new car
2Rismo2
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Jan 23, 2017 10:27 AM
paanta
Aug 13, 2016 02:49 PM
UmmFit
Oct 18, 2014 05:13 PM
patyong
Jun 18, 2011 11:38 PM
Illusive
21
Sep 18, 2007 03:07 PM
