No gages work no indicators on dash no milage and no power sterinf cause
So I went out to my Honda Fit this morning started it up no problems notice the power steering was not working and then I noticed that my RPM gauge and my tach and my Speedo and my gas gauge are not working also when I turn the car to the on position none of the indicator lights click on whatsoever also I changed the alternator thinking that may be the cause of it and no difference when I did change it the alternator test good but there is no charge across the top of the battery while the car is running it will still start with no hesitation except for all my gauges do not work in the electric power steering is out not sure what the cause is whether it is a bad Eld or a ECU or maybe a fuse somewhere not sure where to start any help would be great thank you
coldstorage5
Sep 19, 2016 10:41 PM
