Stock rear height difference
Old Nov 30, 2017 | 03:38 PM
utsug's Avatar
On my 2011 Fit, I noticed that the rear height from the ground to fender lip is different. On the rear driver side it is 25.5 inches while the rear passenger side is 26 inches. My car has stock suspension. My wheels and tires have all the same diameter (195/55/R15).
What would be the problem?
Thanks.
Old Nov 30, 2017 | 03:52 PM
GAFIT's Avatar
If it were a rear drive drag car, it would be called pre-load. LOL
My only suggestion is to look under the car. Make sure that the rear shocks aren't leaking/blown and that the rubber bushings are in place. Was the car purchased used? Could have had aftermarket suspension and they put stock stuff back in, but left out the spring isolator on the left side.
Also, make sure you're parked on level ground and that you don't have anything loaded in the car. 1/2" is not a lot of variance. A small amount of weight or angle of the street can cause that much.
Old Nov 30, 2017 | 04:15 PM
utsug's Avatar
It is purchased new.
Old Nov 30, 2017 | 04:18 PM
GAFIT's Avatar
That's good! Eliminates a lot of possibilities. If it's fully unloaded and parked on a level surface, I suspect it may need new rear shocks.
Old Nov 30, 2017 | 04:53 PM
Frenzal's Avatar
The springs are responsible for the height of the car, not the shocks...
Shocks are just to absorb impact.
Old Nov 30, 2017 | 05:15 PM
GAFIT's Avatar
That is basically true except, gas shocks can have an affect on ride height because they are pushing up against the car at all times....unless the seal is blown.
Old hydraulic shocks have no affect on ride height.
AFAIK, the stock shocks are gas and not hydraulic.
I could be wrong, but I think a 1/2" difference could happen if one side has a blown seal and the other is still pressurized and providing resistance to sag/drop.
Old Dec 1, 2017 | 04:46 AM
Black3sr's Avatar
or could be the fat azzed driver
Old Dec 1, 2017 | 11:58 AM
try measuring without the e-brake applied if you are. thing raises one side more when applied sometimes.
Old Jan 12, 2018 | 10:52 AM
utsug's Avatar
Looks like my left rear suspension is leaking causing it to be lower than the right side.
Old Jan 12, 2018 | 11:05 AM
GAFIT's Avatar
Yup! I believe you found your sag issue.
Old Jan 12, 2018 | 02:13 PM
utsug's Avatar
OEM suspension
Is this KYB GR-2/Excel-G or Monroe 5682 good choice for OEM suspension from Rockauto More Information for KYB 348016
http://www.rockauto.com/en/moreinfo....sn=357&jsn=357
or better get Koni 8050-1131 - Koni Honda Fit STR.T Street Orange Shock
https://www.lmperformance.com/708313...2014-rear.html
Old Oct 6, 2023 | 02:15 PM
B1391's Avatar
Thanks.
I was wondering the same thing on my 2008 Honda fit base I have stock suspension and passenger side sits lower than the driver side
Philip0021
Apr 11, 2024 10:22 PM
radareclipse
129
Jun 1, 2013 12:03 PM
hayden
18
Apr 30, 2012 12:12 PM
MarkyMark
Oct 21, 2008 08:20 AM
TG2008
Mar 6, 2008 01:20 PM
