Fit aerodynamics and wind buffeting
Old Jan 23, 2018 | 09:54 PM
dll932's Avatar
I own a 2010 Fit sport. It kinda bothers me how much side winds affect it even with good tires. The car already came with aero trim, how much good it does I don't know. Anyone here have any experience with air dams & etc. that might help?
Old Jan 24, 2018 | 12:31 PM
Uncle Gary's Avatar
My '09 Sport behaved like a sailboat in crosswinds. You just have to learn to tack to windward, matey! Seriously, it was just one of those things I put up with.
For the record, my '15 Fit is much better behaved in that regard.
Old Jan 24, 2018 | 02:45 PM
GAFIT's Avatar
Adding a Progress rear sway bar greatly helped our '08 GD Fit track better and stay more firmly planted in a straight line at higher speeds.
Old Jan 24, 2018 | 04:46 PM
dll932's Avatar
Now, that's interesting...wonder why?
Old Jan 24, 2018 | 04:48 PM
dll932's Avatar
Mine came with the sway bar. I'll have to check and see if everything's tight back there.
I got a book on auto aerodynamics, after reading it I came to the conclusion it's just as easy to do more harm than good if you don't have a wind tunnel.
Old Jan 24, 2018 | 07:12 PM
thing is narrow, tall, soft suspension, and lightweight.. all recipe for crappy crosswind performance.
in contrast my golfs have no crosswind issue on the same windy day.. and there's really no big aero on the car. it's more to do with lower cog, suspension tuning, and weight of car.
Old Jan 25, 2018 | 02:24 AM
hasdrubal's Avatar
Another vote for the sway bar to reduce body roll. And also for the Golf having the advantage of lower cg and better suspension tuning, but you can get some of that on a Fit with mild lowering springs. My car is significantly more stable with the sway bar and lower/stiffer suspension.
Old Jan 25, 2018 | 07:28 AM
it can if you get the right non-progressive rate springs..
Old Jan 25, 2018 | 03:52 PM
ski's Avatar
ski
If your Fit has stock size tires, try 205/50R16's. They greatly improved my 09 Fit's stability in cross winds.
Old Jan 25, 2018 | 06:50 PM
i seriously doubt that since my GK's currently running 205/50/16's and its just as bad as stock.
Old Jan 25, 2018 | 08:40 PM
GAFIT's Avatar
My Mom felt they improved her '11's highway manners, but that could have been partially just the new tire syndrome where everything seems better just because of the new rubber.
Old Jan 26, 2018 | 07:01 AM
yep. it’s not like the car was screeching to the side of the road from crosswind.. the suspension the weight the shape are the problems.
Old Jan 26, 2018 | 02:05 PM
ski's Avatar
ski
After driving numerous types of vehicles over the past 50+ years, I know what sloppy steering fells like.
My Fit needed large steering corrections with the stock tires in heavy cross winds at highway speeds right off the showroom floor. It felt like it had the old style recirculating ball steering mechanism.
The steering requires only small corrections during the same driving conditions with the 205/50R16's.
4-wheel alignments, spin balances, and frequent tire pressure checks were done for both sets of tires.
Old Jan 26, 2018 | 07:02 PM
in those 50yrs of driving, were you made aware the fit is only adjustable in the front and only toe?
Old Jan 26, 2018 | 09:33 PM
ski's Avatar
ski
Yep, I'm fully aware of that.
However, you're apparently not aware my Fit had alignment components installed to adjust the front caster/camber and the rear camber/toe.
Old Jan 26, 2018 | 10:42 PM
Rob H's Avatar
I have five sets of wheels and tires for my 2017 Fit. OEM 15" tires on some Craigslist Borbett wheels, General Alitmax 195/60/15 snow tires on the OEM steel wheels, 16X7" Tire Rack TR brand wheels with 205/50/16 Bridgestone RE-71R, a set of Maxxam 16X7" wide with 205/50/16 BF Goodrich Rival S and a set of 16X7" OZ Ultraleggera that had BF Goodrich Comp 2's in a 205/45/16.
Regardless of the tire, the car bounces around like a pinball in farm country on a North/South 70mph highway at 75 mph with 15-20 mile an hour winds. Get by a semi truck and it's like the in car footage of NASCAR restrictor plate races. Sure the wider performance oriented tires are better, but only marginally.
It's a lightweight, narrow tall car that's shaped like a tail fin on a airplane. It's going to bounce around regardless of wheel and tire size
Aussie
May 5, 2026 03:53 PM
Mikeyk12
Jan 22, 2013 11:01 AM
supafly50
Feb 8, 2010 09:05 PM
gd3vbp
Jun 24, 2009 01:04 PM
jman245
14
Feb 5, 2008 10:29 PM
