Armrest lid latch part number?
Old Feb 28, 2018 | 01:57 PM
ToddF's Avatar
The latch on my armrest lid broke the other day. Anyone know the part number, so I can order a replacement? All I can find is a part number for the entire lid.
2016 LX
Update: The dealer says the latch isn't sold separately. You have to buy the whole lid for $200.
Old Feb 28, 2018 | 03:56 PM
sjd's Avatar
sjd
I was just about to say that it probably isn’t sold separately. I’d look used from a wrecking yard.
Old Feb 28, 2018 | 04:43 PM
wasserball's Avatar
Without trying to figure out how you broke it can it be fixed using gorilla glue? That stuff bonds virtually everything.
Old Mar 1, 2018 | 10:23 AM
Razor_Burn's Avatar
Repaired one of the covers on a seat belt latch I broke when cleaning my car, and if it's made out of the same plastic as the covers on the seat belt latches then using glue probably won't work to well. The molding mark on the seat belt cover said PP+PE, a blend of polypropylene and polyethylene. These plastics do not bond well with most glues. Locitite claims to have a plastic glue that will, but I've heard the results are mediocre at best.
What I did was use super glue to form an initial hold. Then I used a small piece of ABS filament from a 3d Printer and a Dremel tool to stir weld it back together along the seams. The ABS has a melting temp high enough that the PP+PE melt first and the ABS doesn't get mixed in. The results aren't pretty but it's functional.
Old Mar 1, 2018 | 11:02 AM
Razor_Burn's Avatar
Broke and repaired a seat belt latch cover on my fit. The mold markings indicated it was made of PP+PE it is likely the same plastic used on the armrest latch. These plastics do not like most glues. Loctite makes a two part glue for bonding plastic that has mixed reviews on whether it works or not.
For the seat belt latch cover I super glued it to temporarily hold it in place and used a short piece of ABS filament from a 3d printer mounted in a dremel tool to stir weld the pieces back together. ABS Melts at 220C while PP+PE is somewhere around 160 so the ABS shouldn't mix in. It doesn't look pretty when you are done, but at least it holds.
Old Mar 2, 2018 | 10:48 AM
fitchet's Avatar
Yep, if I was a gamblin' man..my bet would be Honda makes you buy the entire lid. But I could be wrong.
So I think you have all the advice you can use.
Either junkyard salvaged.
OEM full lid replacement.
OR....the wonderful world of bonding agents and their success's and pitfalls.
Good Luck.
Old Mar 2, 2018 | 09:12 PM
ezone's Avatar
2016 LX
Is the car out of the 3 year/36,000 miles bumper to bumper warranty?
Old Mar 7, 2018 | 02:24 PM
ToddF's Avatar
Unfortunately, I just passed 36,000 miles a couple months ago. Didn't even realize it until I took it in for an oil change and they mentioned I had just a couple hundred miles to go on the warranty.
Old Mar 8, 2018 | 11:04 AM
wmo168's Avatar
If it pass 36k recently Honda usually can do a courtesy warranty as a one time thing.. I would try go service and talk to the adviser and see what they can do,.. maybe they give you a discount. Doesnt hurt to ask..
Old Mar 8, 2018 | 11:15 AM
2Rismo2's Avatar
How did the lid latch break? I think this is the 2nd thread I've seen where it broke so just curious.
bulldogtrekker
13
Mar 28, 2024 11:14 AM
SilverStreak
Apr 25, 2012 04:53 AM
Raouf
Feb 2, 2010 01:44 AM
junktea1
Mar 12, 2008 10:49 AM
sonicsc1
Jul 12, 2007 01:06 PM
