Fit hesitating, twitching and stalling in low RPM under load - video included
Hi guys, I just bought an old neglected Fit for cheap, and I'm trying to fix it up. It's doing this:
I did some research and it might be coilpacks or sparkplugs? Unfortunately I don't have OBD2 reader to see what the check engine code is.
Just wanna ask your opinion before I start throwing parts at it.
It's a japanese import, 03 Fit with CVT
Many thanks!
Many thanks!
Yep, with these near bulletproof cars, you cannot worry about anything major until the "big 3" are taken care of. Ignition coils, iridium spark plugs and a valve adjustment. It will run you some money but the big 3 are probably responsible for the majority of performance problems with the Jazz/Fit. Good luck sir.
May have found the problem
https://i.imgur.com/V8W6p1a.jpg
One of the coils is broken. Couple others are pretty oxidized - so that probably means I should replace all, right?
Yes. Changing ignition coils one at a time has proven to be ineffective according to many members of this board. Buying cheap replacements has also proven to be a mistake. Stick with Hitachi or Denso products when dealing with the ignition system. When you take out the individual coils, make sure that the spark plugs are properly torqued. If not torqued properly, gases can emanate around the aluminum gasket and foul the ignition coils.
You should do yourself a favor and go buy one. Ultragauge, scangauge, Torque(+bluetooth), OBDLink (+bluetooth/"wifi"). etc... there are a lot of options and most are inexpensive.
Hah, I already ordered coils from Aliexpress for $100. I'll report back here how they turned out. (Or won't, if my car explodes)
OBD scanner is on the wishlist.
Thank you, BurntZ and Goobers for help!
I got another update:
1. Adjusted the valves - all of them were a bit too loose, but not by much, usually 0.02mm over spec. So I set them in the middle of factory specifications.
2. Changed the spark plugs - when I took out the front spark plugs, they actually didn't look too bad. But the rear ones were a different story: https://i.imgur.com/4Z2D6xW.jpg . I think what happened is some absolute legend changed only the front ones, and the rear ones are original from the factory. So if the car somewhat ran with all this, I'm hoping it will be a rocket when it's fixed.
3. Checked out the engine mount - here's pictures: https://imgur.com/a/nwb5s . What do you think? Is it too loose?
4. Another can of worms on this car is the suspension - how about this top strut mount? Is it supposed to be loose and squeaky like this?
Can somethign be done?
G'day,
I had pretty much the same problem, 195,000 km. I replaced one coil that had visible damage but the problem remained. looking at the old coil unit I noticed the coil boot was pretty much fried so I replaced the coil boots on the other 3 and it totally disappeared. I felt in heaven driving!!! Most places don't sell coil boots though, I got a set of 4 from china thru aliexpress for $16, took about 2 weeks for delivery.
Cheap chinese coils also available for around $60-70 set of 4. Sounds bad doesn't it "cheap chinese coils", but I think most items are made in china anyway nowadays.
Good advice above to do the timing, that'll go a long way helping remove the problem.
ooh, I had no idea you can replace just the coil boots! I might try it on my friend's Fit that's doing the same thing. Thanks blood dog.
Also, I've been told the loose top strut mount is a feature, not bug.
Hey guys, so it's fixed! Thanks everyone for help!
(in the video it seems like the sound is cutting out - that's just my crappy phone)
I installed new sparkplugs NGK BKR6E 11 from Supercheap Auto and highest grade chinesium ignition coils from Aliexpress: https://www.aliexpress.com/item/8PCS...460.0.0.KiM8ZO
Just did a short test drive and all seems to be working. I'll update how are they holding up after some more driving.
Btw, the coils I got from Aliexpress look identical to the original ones and have Hitachi stamped on them. Are they still fake or do they actually sell genuine parts on Aliexpress?
4. Another can of worms on this car is the suspension - how about this top strut mount? Is it supposed to be loose and squeaky like this? https://www.youtube.com/watch?v=Jo-10_QPcHg Can somethign be done?
In older cars (1979 Supra, 1987 Camry etc) the upper front strut rod end is passing through the bearing in the upper strut mount; the outer diameter of the bearing is held stationary relative to the car's body. So when front wheel turns, the entire strut housing and its center rod were tuning as a one piece. Contrary to that, on Fit only the strut housing is rotating relative to the strut rod (the bearing is placed between upper spring seat and center strut rod) The rod is held stationary relative to the body. The upper and lower cushions are used to dampen noise and vibration (like on rear struts) and allow some tilt of the strut relative to the body during turns.
If on your car the upper cushion moves with car on the ground the bearing is stuck; if it moves when car is on the lift the upper cushion is worn.
Makes sense! Thanks doctor J!
The noises I heard from front suspension seem to be caused by the swaybar. I removed one of swaybar links and it's quiet now, so I'll replace the links and try to lube the swaybar mount, but it looks like it's super tight. Found this video:
(elevator music warning)
dblancer
Jun 9, 2017 02:50 PM
radiolandog
Jul 11, 2014 09:40 AM
danielomar91
Jan 24, 2014 11:29 AM
