DIY: GE Armrest Delete Plug $3
Old May 29, 2018 | 11:56 PM
eulogy's Avatar
Ok so since this forum has helped me out a ton in the short time Ive been here, I thought I would give back a bit and create a mini how-to on my GE sport model armrest delete plug, in the event you got a aftermarket armrest without a plug, or just dont like your OE armrest and wanna get it out of there. I searched site but didn’t see anything DIY, though I may have missed it. Anyways, I installed my aliexpress center console today, and it didn’t come with an armrest delete so I improvised. I probably would have done this even if I didnt get the aftermarket armrest as I really didnt like the position of the OE seat mounted armrest. And its kinda ugly in the up or down position.
First I pulled off the oe armrest to see what I was dealing with. After removing the cap there is a bolt and 2 supports/stops in there. Pulled those out and was left with this gaping hole.
Next I went to True Value hardware store, blindly, as I have faith in them for odd projects like this. Fortunately it worked out on the first try, which usually doesnt happen with my projects, no matter how simple they are. Anyway, I think True Value is better better than Lowes or Home Depot in my area because they have an awesome selection of random hardware and they let you buy any quantity vs packs.
So first thing I got was 1 of these Nylon Knock out seals.
Then I got 1 of these Automotive Panel Fasteners. The one on top of the box is my first choice which I thought was a bit too short. The one I finally went with was about 4mm longer, which is the "4819-R". Either size probably would have worked but its better to go too long and trim it down if needed.
Get ready for some Dremel cut-off wheel action !
Then I was left with this
Grinded it down a bit…doesn’t need to be too pretty as this side will face the seat. Then took it inside and got the fastener ready
Cleaned the contact areas with acetone, then Put a drop of Go2 Glue, and then gave it a good dose of hot glue (the best glue for the impatient).
Looks like hell, I know…I usually do cleaner work but I knew I wouldn’t be able to see any of this.
I almost just bought a short bolt to reuse the original plug, but it is definitely too small. Heres a comparison. The larger one is about 60mm and barely covers the hole.
Ok, off to the car…lined it up and gave it a few hammer fists…and bam!
Going to take my rubber mallet to it tomorrow to even it up and get it a little deeper after the Go2 Glue cures. Overall I think it looks better than the zeta plug and best of all cost 3 dollars...assuming you have glue!
The end!
Old May 30, 2018 | 12:29 AM
marmaladedad's Avatar
Very nice!
Old May 31, 2018 | 04:00 PM
evilchargerfan's Avatar
so simple, but such a nice result. well done
Old Oct 24, 2024 | 01:49 PM
fitturismo's Avatar
Nice DIY!
For those with a 3d printer or access to one, , I used this: https://www.printables.com/model/995...ge-2nd-generat
korgster
Apr 15, 2015 02:26 PM
polokid69
Sep 5, 2012 06:35 PM
zetaproducts.net
Zeta Products.net
Sep 23, 2009 02:30 AM
diskullman
Dec 30, 2008 02:40 PM
