Air Intake and Exhaust Modification causing 02 sensor code
Old Jul 8, 2018 | 03:48 PM
catmosca's Avatar
Hello fit forum,
Picked up a 2008 Sport MT at an auto auction. The previous owner replaced the air intake, the headers and the muffler/tailpipe as well as lowering the vehicle. The engine light came on as I pulled away from the lot. The codes were P2A00 and P1172. I am worried that the system is running open loop. The car was sitting for a while with a full tank of gas therefore I added some seafoam. Is the O2 sensor code a product of old gas, the modified air intake/exhaust, a faulty O2 sensor or a combination of those things? I'm going to burn through this tank and add some premium fuel to see if that helps. I have the old air intake and exhaust parts if any of you think it would help to put them back on. Suggestions are greatly appreciated. I purchased this car for it's fuel economy and although it's fun to drive modified it's not worth it to me to burn through gas. Thanks!
Old Jul 8, 2018 | 03:59 PM
ezone's Avatar
P2A00 and P1172
Replace the AF sensor (primary O2 sensor). Done.
Old Jul 8, 2018 | 07:26 PM
catmosca's Avatar
Thanks I'll give it a shot.
Old Jul 8, 2018 | 09:31 PM
yanbros's Avatar
Have you tried clearing the codes? I have done lots of exhaust work on my jdm ge6 and those on cvt are very sensitive. Every time I swap a exhaust manifold or cat, it will need a code clearing. I’ve also added a defouler for added measure.
Old Jul 8, 2018 | 11:05 PM
catmosca's Avatar
I tried clearing the codes but they came back after a few minutes of driving.
Old Jul 8, 2018 | 11:12 PM
ezone's Avatar
Make sure you use the same brand sensor that Honda installed from the factory. It's either NTK or Denso. You may need to remove yours and clean it with a wire wheel to find the brand name stamped on it.
Each brand has a website you can look up the part number for your sensor.
Old Jul 13, 2018 | 02:10 PM
catmosca's Avatar
Replaced the sensor with a Denso. The check engine light is still on. What's my next step? Thanks.
Old Jul 13, 2018 | 04:02 PM
ezone's Avatar
Didn't you erase the codes when you replaced the sensor?
Does it now have the same code or a different code?
Old Aug 2, 2018 | 11:48 AM
upallnight's Avatar
You have an MT Fit which uses a different sensor from an AT Fit.
​​​​​​Fit M/T……..36531-RME-305, H/C 9182809
Fit A/T……..36531-RME-306, H/C 9182817
Verify that you bought the right sensor.
Jutboy
15
May 16, 2024 07:11 AM
Destiny
Dec 8, 2017 04:20 PM
MTLian
Apr 10, 2014 05:37 PM
cdninsw
Feb 20, 2014 05:33 AM
brs5tettba
Dec 9, 2013 06:10 PM
