Low fuel rail pressure p0087, fixed itself, any ideas
Old Jul 11, 2018 | 02:51 PM
andy342's Avatar
Car went into limp mode the other day. Engine lights on etc. Girlfriend got towed home by AAA.
Torque app showed P0087. Fuel rail showed about 36psi give or take. I pulled out the in tank pump, took it apart, no signs of anything clogged, seems to pump fine using isopropyl and then gas.
Reinstalled the pump, cleared the code, started the car and burped the throttle a couple of times. Rail pressure was 500psi at idle, jumping to 750 to 1000 as the revs picked up.
Has anyone worked on the direct injection systems on these cars? Nobody likes a problem that magically fixes itself.
Will do a test drive in a couple hours.
Any input would be appreciated, thanks
Old Jul 11, 2018 | 07:26 PM
ezone's Avatar
Code sets when the high pressure pump can't build sufficient pressure in the fuel rail, or sensor readings indicate to the PCM that situation may have occurred.
Got freeze frame data you can post?
If it runs out of gas and the engine stalled because of it, it will definitely set the code.
If it's very low on gas it could happen if the in-tank pump cavitates or starves long enough to interrupt the supply to the HP pump and rail pressure drops (below a threshold) for longer than about 3 seconds.
If either of these could have been the case, just add more fuel, clear the codes and drive it.
If you saw 36 psi with just the key on and the in-tank pump ran its 2 second prime, that's probably normal until you start the engine and the HP pump can build pressure.
Yea, intermittent issues can really suck to figure out if it's not acting up while you're checking it out, especially when it's a real problem.
HTH
Old Jul 12, 2018 | 12:06 AM
andy342's Avatar
I saw 36psi with the car running at idle in my driveway.
Old Jul 12, 2018 | 12:11 AM
ezone's Avatar
Well that isn't right, but getting it to act up again long enough to figure out what's going on will be the hard part.
Still under warranty?
If you erased the codes they won't have anything at all to work with. It will have to set the code again.
Old Jul 19, 2018 | 08:12 PM
CommanderSlug's Avatar
Maybe it's just a hiccup. The fuel pump you took out is probably the low pressure pump. I ran out of gas once ... no codes thrown.
Old Jul 20, 2018 | 10:08 AM
James Butler's Avatar
andy342
how do you reset the limp mode code. Scanner ? what kind or disconnect battery.
Old Jul 20, 2018 | 10:25 AM
ezone's Avatar
Either way.
Any code reader should also be able to erase powertrain codes.
Honda allows you to clear powertrain codes by disconnecting the battery or removing power from the PCM.
But if the problem is still present then of course the code(s) and associated issues will be present again too.
EDIT: This might not apply to all situations and codes.
Old Jul 20, 2018 | 10:44 AM
vinylengraver's Avatar
Plus, if the issue is hard to replicate and/or intermittent, when you erase the code before taking the car for service you possibly leave them with nothing to work with.
I am not sure if this PCM has a stored codes/shadow codes feature.
My previous car would store so called "shadow codes" that could only be read with specialized OEM diagnostic equipment, off-the-shelf code reader would show nothing.
Old Jul 20, 2018 | 12:22 PM
When I went in limp mode I disconnected the battery for about 20-30 minutes and still in limp mode. Dealership told me it takes a special Honda diagnostic tool to reset limp mode. They claim their readers hooks straight to PCM not OBD2 port. Nothing wrong with Fit except limp mode triggered. Car was at Dealership all day. Just looking for a way to reset it if it happens again. Next time I plan to go straight to Autozone and tell them if their code reader will reset it I will buy the code reader from them.
Old Jul 20, 2018 | 12:37 PM
ezone's Avatar
Fake news.
The interface unit for using the Honda HDS and IHDS scanner program connects to OBD port just like any other.
JG
Sep 23, 2017 01:26 PM
Comax2
Jun 1, 2016 04:26 PM
Myxalplyx
May 11, 2016 12:29 AM
clanbuster
Mar 18, 2010 02:45 PM
prossett
Dec 20, 2007 10:46 AM
