What kind of glue should I use inside my headlight housing?
Old Jul 15, 2018 | 10:06 PM
GD3 GeGe~'s Avatar
Got some LED tubes im going to install inside my headlights but what kind of glue should I use. The LED tubes are a silicone rubber material looking to install it on my plastic black painted housing.
THX!
Attached Thumbnails What kind of glue should I use inside my headlight housing?-screen-shot-2018-07-15-7.07.54-pm.png
Old Jul 15, 2018 | 10:08 PM
xxryu139xx's Avatar
don't use glue. drill some tiny holes and use either nylon string or jeweler's wire.
Old Jul 15, 2018 | 10:11 PM
GD3 GeGe~'s Avatar
I just edit a photo
im curious wouldn't the strings show?
Old Jul 15, 2018 | 10:16 PM
xxryu139xx's Avatar
no unless u look real hard.
Old Jul 15, 2018 | 10:19 PM
GD3 GeGe~'s Avatar
Ok thx for the help!
Old Jul 15, 2018 | 10:23 PM
xxryu139xx's Avatar
all these leds, halos, tubes, they all fail. if u glue them, there is no turning back. if u use wire, u can always remove it cleanly. and then redo if u must.
Old Jul 15, 2018 | 11:26 PM
GolNat's Avatar
Tiny holes would allow moisture to get in would it not?
Silicon would hold it well and not be difficult to remove.
Old Jul 15, 2018 | 11:37 PM
xxryu139xx's Avatar
u won't be drilling through the whole headlight. it will just be where the shroud/reflectors are which are contained inside the headlight.
Old Jul 16, 2018 | 07:08 PM
i suppose u could caulk da holes..?
Stacey444
Jul 30, 2019 10:50 PM
smeister
31
Aug 3, 2014 04:18 PM
Dark_templar
Jun 4, 2013 10:08 AM
HONDAMATIC
Apr 14, 2010 11:39 PM
eglamkowski@angelfire.com
Sep 26, 2005 10:30 AM
