3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Rigid Collars
Old Aug 23, 2018 | 06:41 PM
evilchargerfan's Avatar
Post Rigid Collars
My buddy and I were able to tackle this install relatively easily. We didnt have a lift or much fancy equipment, but still able to finish in under 2 hours.
Rear collars were insane simple:
-jack up the rear end
-remove wheels
-before removing bolt, support with a jack
-unbolt bolt in question, slap on collar, and re tighten.
Fronts were not as simple as the rears, but not too tough:
-Jack up the front end
-Remove wheels
-Loosen all 4 bolts to allow some slack/movement of the subframe
-Install FRONT collars, top one first, then bottom one onto bolt. Insert bolt and hand tighten
-Install REAR collars next. Exactly as you did the FRONT collars. May need to remove a nearby bracket and bolt if more clearance is needed
-Tighten it all down with your impact gun, and marvel at your awesome ride
Using this graphic, we'll call position 3 "FRONT" and position 2 "REAR"
For those who own a lift and have a means to support the sub frame, my guess is the install is easy beyond easy. My install was on a driveway, we had to do 1 side at a time. That said, we did have to use a big friggin Pry Bar in order to create a gap to insert the upper collars:
FRONTS pry angle:
REARS pry angle:
Here is the hardware for the FRONTS and how the finished product should look:
Here is the hardware for the REARS and how the finished product should look:
Conclusion = HIGHLY RECOMMENDED. The diff in feel these little collars make is night and day!
These collars can be bought on ebay, and other places. google is your friend folks. There are also other brands out there like Spoon, Magic Collar, etc
Old Aug 23, 2018 | 06:42 PM
here are the included (and horrible) instructions:
GAFIT's Avatar
Nice write up!
Old Aug 23, 2018 | 07:11 PM
thanks! for those who will ask "HOWS IT FEEL" .... the below would better illustrate what these collars are good for:
Rigid Collars
https://www.s2ki.com/forums/jdm-tuni...k-ap2-1036470/
Very very pleased. I wanted to add the rigid collars specifically to be able to handle certain types of roads more effectively and reduce some of the harshness in the feedback and they have done exactly that. They also act as insurance that the subframes will remain precisely in place. Not necessarily a major concern, but it seems there are plenty of instances where people's subframe bolts were loose and may have allowed for more play than desirable. This is a relatively expensive modification, with the cost of the collars themselves, the cost of the install (need the proper equipment to drop the subframes), and a fresh alignment. Money very well spent in my opinion though. Anything that increases driving feel at all is worth it in my book, and this is quite an improvement. Of course I will be testing these at the track as well (I will be at Laguna in early September) but honestly a track test isn't required to feel the difference. But increased driving feel = increased confidence in the car which usually = faster lap times
Old May 4, 2019 | 01:17 PM
Subhan Yushan's Avatar
Hi there,
I am in doubt..there are 2 pieces number 20004430. Any idea where should they be applied? On their product description page they called it as "spare bushing"
Old May 6, 2019 | 02:05 PM
I am not 100%. And I simply left those aside
Old Apr 12, 2020 | 07:23 PM
Fergus's Avatar
What's torque spec on these?
Old Apr 13, 2020 | 11:42 AM
for the ones that touch the LCA, 69 lbs. my guess is, the ones that touch sub frame are the same ... I think?
https://www.fitfreak.net/forums/3rd-...ml#post1403042
you may wanna sift through that K.I.S.S thread and see if anyone else posted up more torque specs
if not... someone else in another thread, did post up info on how to access the Chilton Library, which is where I got all of my info (and if you look at the thread, pretty much ALL of my posts are just snips from that chilton library)
Old Apr 14, 2020 | 11:53 AM
Fergus's Avatar
Thanks for getting back with this.
suketoborudo00
Jun 13, 2020 10:42 PM
Kuturagi
Mar 29, 2012 04:25 AM
xorbe
Jun 14, 2008 04:00 PM
F-IT!!!
Dec 23, 2007 02:25 AM
F-IT!!!
Nov 18, 2007 12:38 PM
