Back up camera
Old Sep 3, 2018 | 10:32 PM
siguy's Avatar
Back up camera
Does anyone make a back up camera for a 2013 Fit Base?
Old Sep 4, 2018 | 05:30 AM
Rigaudon's Avatar
I bought this one and it fit perfectly.
https://www.ebay.com/itm/For-Honda-C...item33d6850933
I wired it to an aftermarkey JVC KW-M730BT. I tapped into the reverse lights. You have to take off the rear hatch cover to install and then route the wires through the rubber wire connector from the hatch into the car which was a challenge. I installed it late 2017 and it's been working fine since.
Old Sep 4, 2018 | 04:42 PM
eulogy's Avatar
Old Sep 5, 2018 | 07:25 PM
sean.haynes's Avatar
Im pretty sure I saw a youtube video of something doing this same install.. the fit is so small I have no problem parking it. However, after upgrading to a double din and now having the option, I am tempted..
Was it worth it to you? Im more curious in the quality of the camera.. is it good?
Old Sep 14, 2018 | 02:08 AM
narrator's Avatar
What head unit are you going to hook your camera up to?
There are a lot of cheap options on AliExpress, possibly eBay/Amazon too.
I bought this camera off of AliExpress, I haven't installed it yet, though.
I hope to do so this weekend.
I currently have the Auto-Vox X1 Pro rearview mirror installed on my car and am using that camera. Sorry no pics of this, I may do a post about this in the future though. The camera is installed using one of the license plate screws.
Old Sep 18, 2018 | 03:08 AM
GE82010's Avatar
https://www.amazon.com/gp/aw/d/B06X97YNHS?psc=1&ref=yo_pop_mb_pd_title
bought this one has night vision l
e.d that turn on
Old Sep 18, 2018 | 05:16 PM
Rigaudon's Avatar
It's definitely not necessary, but because I had the double din headunit and I could, I tried it out. Also, I was having trouble backing up at night down a long straight paved driveway. I upgraded the reverse lights to LED's (which helped a bit) and then added the backup camera. The night vision is ok, and it does help me navigate that driveway. I also like that you know how close you can get when parallel parking or backing up to something. That part is nice.
As a side note, we have two 2012 Base Fits and my stepson (age 26) said "do not add a backup camera to his Fit". He is old school (at 26), and finds the backup camera distracting. I like it and find it works well.
The camera quality is surprisngly decent. Not high def, but clear enough.
Old Sep 24, 2018 | 01:53 PM
Nick Farley's Avatar
https://amzn.to/2QRE4XH This one works really well for me.
Old Sep 24, 2018 | 07:06 PM
eulogy's Avatar
how doea this function with the LEDs?
i assumed they only turned on when in reverse and left one side of the license plate dim the rest of the time?
Old Nov 8, 2018 | 08:29 PM
luchobucho's Avatar
i have one like this. Its okay, the camera quality isn’t great.
Old Mar 12, 2019 | 05:12 AM
jthai's Avatar
Sorry to bring up an old thread but do any of you have pics of what your reverse camera looks like installed? Specifically the ones that have the integrated camera to the clear reverse light housing. How low does it protrude and does it have a decent angle? I cant find any pics online of this style actually installed. Thanks.
Old Mar 12, 2019 | 06:12 PM
luchobucho's Avatar
it protrudes a couple inches below the light cover. It doesn’t protrude out beyond the vertical plane that defines the back of the car. The view angle on my camera is very wide so I can see the entire width a car behind me even when I’m very close. The camera I bought on eBay is feom
china and is really terrible quality. I’ve thought about buying a new high quality one and trying to figure out how to install it.
Photos below.
Old Mar 13, 2019 | 12:07 AM
jthai's Avatar
Nice! Thanks for the pics Bucho. There’s a camera on Amazon by company called Navinio that I’m thinking of buying. Does your setup change the light pattern of the parking lights when on at night? What I mean is do the two rear lights still look uniform?
Old Mar 15, 2019 | 01:28 PM
IfChris_ThenFit's Avatar
Re-revivng a thread that was just revived. Sorry guys!
anyone have any guides on routing the cables?
Also as usual, I intend to tap into the reverse light power. any recommendations?
Thanks!
Old Mar 15, 2019 | 05:02 PM
marmaladedad's Avatar
Thanks!
I routed mine underneath the door sills, from the rear of the car to the front. There is just barely enough cable (in my case) to do so. I may try running it through the headliner from rear to front this weekend to see if it does not clean up the bits of exposed cable. As for connecting to the rear light wires, I used some wiring T-taps to simplify the process (instead of stripping, soldering, and heat shrink). Some may balk at the usage of these, but it is up to you. I have had no problems with them so far.
Old Mar 16, 2019 | 01:27 PM
Any reccomendations on what exactly to get? wire gague? Thanks!
Old Mar 18, 2019 | 09:54 AM
The one I purchased was from Amazon -
Amazon Amazon
I did not have to use any extra wiring. A wiring harness is included that you need to connect to your existing backup lights, whether it be by cutting/soldering or some wire-nuts or taps.
Old Feb 11, 2020 | 01:01 AM
MarkP's Avatar
Installed my back up camera and I am happy with how it looks (OEM like) and clear output from my HU.
Old Feb 11, 2020 | 01:03 AM
MarkP's Avatar
How it looks like installed on my Honda Jazz/Fit GE
Old Feb 12, 2020 | 10:27 AM
I like the integration of the camera. Looks good.
