215/45/16 tires
You are correct! Here are the numbers...
185/60-15 - 23.7 diameter
205/50-16 - 24.1 diameter
215/45-16 - 23.6 diameter
185/55-16 - 24.0 diameter
Personally, I'd go with the popular size with lots of choices since all are pretty close.
How much does the Eibach kit lower the car? If its only an inch you should be ok. .4" is about 10mm which would be like running a 40 something offset wheel.
Are they all season or summer/winter tires? I go as wide as possible for my summer tire.
OP:
Run a 195/50/16. You can get a nice tire in that size, it is close to OEM diameter & it isn't needlessly wide like a 215 would be.
By the way, offset is really important, so do your research and check what is doable.
I know that. I assumed he was referring to .4 wider not taller and I know it does not change the offset.
so i could get away with a 15x7.5 even?.. Asking purely for the desired fitment over all else. Also beer, this post is brought to you by beer.
Offset without rim width means nothing. Offset is the amount the the wheel is offset from the centerline of the rim. The same offset on a 6" wide wheel and 7' wide wheel will change the relationship from the wheel to the strut. As one goes wider rim width at some point the offset needs to be reduced to keep from the wheel touching the strut.
SEARCH. There are multiple threads about wheel/tire fitment with various suspension choices.
Santiad
Nov 10, 2011 05:33 PM
