do 2015 honda fit tires fit on 2007 honda fit
Old Sep 11, 2018 | 10:57 PM
Hondafitdriver's Avatar
hey guys I have a 2007 Honda Fit and I'm looking at pair of tires from a 2015 Honda Fit would they fit on my 07 ?
since mine are 195/55 R15 and the ones I'm looking at are 195/55 R15
Old Sep 11, 2018 | 11:00 PM
GAFIT's Avatar
That is the correct size for our car, but that's not the size on the 2015. The base '15 comes with 185/60-15's. Higher trim levels come with 16" wheels.
If they are in fact 195/55-15's, then yes they will fit.
Old Sep 11, 2018 | 11:21 PM
ok so the rims or wheels will fit is that correct? also the ones I'm looking at are winter tires that the side Walls say 195/55 R16. I think the wheel are stock and that someone just threw winter tires on.
will that have an effect on the cars speed also?
sorry I should have been more clear in the beginning with my questions
Old Sep 12, 2018 | 01:27 PM
GAFIT's Avatar
In the first post you said they were 15" wheels. If they are 16" wheels (last digits on the tire specs), then that is an inch larger diameter than factory. I would not go that tall on a 2007 Fit.
Old Sep 13, 2018 | 03:33 PM
GolNat's Avatar
Compare sizes here:
https://tiresize.com/calculator/
The wheels (rims) will fit if you are concerned about that also.
Old Sep 15, 2018 | 09:51 AM
Originally Posted by GolNat
Compare sizes here:
ok so it wouldn't be worth putting 16s on it?
Old Sep 15, 2018 | 03:26 PM
GAFIT's Avatar
You just have to watch the total diameter. Wheel diameter is only part of the equation.
Use that tire calculator above or try www.willtheyfit.com to see what sizes are close to stock.
Tire size work like this...first number is width in mm, second number is the percent of the width that is for the sidewall. Meaning that a 195/55 is 195mm wide and the sidewall is 195x.55 = 107.25mm tall sidewall.
For overall diameter, you have to include the sidewall twice. So, 107.25 x 2 = 214.5. Convert to inches - 8.44 inches
So, if you put that tire on a 15" wheel, you have a total diameter of 23.44. Put that spec tire on a 16" wheel and you have a 24.44 diameter.
My point is that, if you go up in diameter, you need to go to a tire with less sidewall (ie. 45 aspect ratio) in order to keep the overall diameter the same.
Short answer is that a 195/55-16 is too tall for your car. Also, it's better to go down in wheel diameter for snow tires instead of up. You want more sidewall for better impact resistance. Most run 14 or 15" wheels for winter use.
Old Oct 3, 2018 | 03:27 PM
hey sorry I haven't been able to reply sooner it looks like you put a lot of time into to your reply and I just wanted to say thank you so much for helping me out with this.
Fitfreakuser
Sep 24, 2018 08:11 AM
solenoid
Nov 5, 2017 03:57 PM
oveedrx
Jan 4, 2015 08:07 AM
1x1
Oct 27, 2010 07:24 PM
FitCanada_Girl
Dec 12, 2009 08:19 PM
