When should I care about valve noise?
Old Oct 20, 2018 | 06:43 PM
fujisawa's Avatar
@37K miles my 2012 Fit Sport AM has developed what I think is additional valve noise. It is unnoticeable at idle and at higher speeds, but when coasting at very-low-but-not-zero throttle, or accelerating very slowly, there is a multitude of rattles from ahead of me. Sounds like tiny marbles on a gently shaking steel pan.
It's still very quiet through. For example, I'm sure darling Wife has not noticed a thing yet. So my question is: When should I be concerned? I'm not afraid of pulling the top of the engine off and doing the valve adjustment (and presumably spark plugs if it requires taking the cowl off). But I AM afraid of going to all that work and finding out everything is still in fine condition. Should I wait for this to get worse? Will it get worse, or will something break suddenly?
This is pretty low mileage to have trouble with valves ... We do not put a ton of miles on the thing.
Old Oct 22, 2018 | 11:27 AM
GAFIT's Avatar
I'm betting it's a rattling exhaust heat shield or something else similar.
Valve adjustments are definitely a major important part in a good running Fit, but you're just not anywhere near the miles that would require one yet.
ommegga
Feb 14, 2020 12:21 PM
allTRACway
Mar 11, 2016 04:06 PM
poopshovel
May 25, 2011 11:23 PM
Spooling
May 23, 2009 11:00 PM
chibitul
Aug 10, 2005 06:31 PM
