Valve noise after adjustment. Video included
Old Mar 31, 2018 | 02:20 AM
ommegga's Avatar
So this morning I adjusted valves on my 13' Sports. All exhaust were super tight, in the .006 range. The engine has been getting very queit so I already suspected it. Intake side was ok, few were bit loose.
Spark plugs were replaced to ik22s, although stock ones were in excellent shape. I also installed Spoon throttle body
The car runs beautiful, no CEL , smooth idle and excellent pick up but the valve train noise is way, way louder. I put the exhaust valves at 0.012 thinking they will loose overtime but didn't think they will get this noisy. I'm just about to install Ktuner and I'm not sure if I should leave like this or go ahead and get the lash down to 0.010 on the exaust side.
Here is the video:
Old Apr 2, 2018 | 12:32 AM
perkidddoh's Avatar
It sounds a bit too loose, I did mine this week and I had to do it three times before getting it correctly.
My rule is this: anything greater than the range should NOT fit at all.
Hope this helps.
Old Apr 2, 2018 | 01:42 AM
ommegga's Avatar
Hope this helps.
I see.
I'm doing it tomorrow morning again. Will use the go-no go technique. Will go with 0.010 on exhaust side and 0.006 on intake side.
Old Apr 2, 2018 | 01:08 PM
ommegga's Avatar
So I redo all the valves again and the car purrs like a kitten now . There were all too loose on the exhaust side. There was a "drag" on .012 but you could fit .014 .
Old Apr 2, 2018 | 06:19 PM
perkidddoh's Avatar
Awesome!
Doesn't it feel so satisfying? Good to know the second try fixed it.
Old Apr 3, 2018 | 02:38 AM
ommegga's Avatar
Awesome!
Oh yeah definitely. And now I can get to the valves in less than 20min
Old Apr 5, 2018 | 09:47 PM
Li2099's Avatar
Hope this helps.
Good info.
I'm about to venture into my first valve adjustment.
Did buy the auto transmission filter as I'll be taking apart quite a few parts too.
Old Jan 6, 2020 | 07:38 PM
nixxon's Avatar
Here is the video:
https://youtu.be/BioHpAIld-o
Hi, just wanted to add, the exhaust valves always tighten, not loosen, so should be set at their max. Intake set middle or low range
Old Feb 14, 2020 | 12:21 PM
mxl180's Avatar
My had a similar sound after I adjusted the valves. The 1st time doing it was a little loose and realized I let the shim slide to easily. 2nd time doing it lessin the noise.
fujisawa
Oct 22, 2018 11:27 AM
danielmorrison
Jan 26, 2018 09:47 AM
allTRACway
Mar 11, 2016 04:06 PM
Spooling
May 23, 2009 11:00 PM
chibitul
Aug 10, 2005 06:31 PM
