Ticking sound
Old Jan 24, 2018 | 04:01 PM
danielmorrison's Avatar
Ticking sound
I have a 2011 Honda Fit with 138,000 miles and yesterday it started making a Louis ticking sound aside from that everything else runs fine
Here is a video
Old Jan 25, 2018 | 11:53 AM
Mister Coffee's Avatar
Hard to tell from a video, but here's a guess:
1) "Started yesterday" doesn't make sense to me. Normal valve train noise is usually gradual, and I don't hear anything abnormal.
2) If you haven't adjusted the valves in the last 30k mi., I would start with that.
3) I have 50k mi. on my '13 Fit and, from the beginning, I have always thought our injectors were loud. Not a problem, just loud. So, it makes it a little harder to diagnose valve noise.
Good luck, hombre. 😊
Old Jan 26, 2018 | 09:09 AM
Also now my check engine light came in and it started shaking and almost stalled out. Any thoughts? But no code showed
Old Jan 26, 2018 | 09:31 AM
GAFIT's Avatar
Stop driving it now before you do additional damage.
If you're up for the task, start by checking the plugs to make sure they are tight and check the coils to see if they have soot (sign of leaking plug).
Then do a valve adjustment.
If you're not up for that task, get it to a mechanic to have them check the plugs pronto. If it has a loose plug and you continue to drive it, it may eject the plug and take the threads with it. That gets expensive.
Old Jan 26, 2018 | 09:43 AM
As soon as the light came on I took it to my mechanic he lives close.
Old Jan 26, 2018 | 09:47 AM
GAFIT's Avatar
Great to hear! Make sure to let him know to check the plugs and coils to look for signs of leakage. Few are familiar with this issue and it's common to the GD and GE Fit's.
Please report back what he finds.
ommegga
Feb 14, 2020 12:21 PM
l3igl3ang
Mar 17, 2019 07:10 AM
utsug
Nov 17, 2017 01:12 AM
Fitguy07
Jun 24, 2014 09:14 PM
Pith
Mar 20, 2011 12:30 PM
