Advices on Header fit ge8
Old Nov 14, 2018 | 05:58 AM
Vamprie Nong's Avatar
Hi guys, I just want an advice how to change the header for fit ge8. What do I need to remove before I can access to the header and what size of the socket do I need for it. Any advices would be greatly appreciated. Thanks all😀
Old Nov 14, 2018 | 12:29 PM
GAFIT's Avatar
Does your GE have an L15? If so, it does not have a header. The cylinder head incorporates what would be a header and it only has a downpipe.
The downpipe was very easy to remove on my friends. Just have to remove the bolts for the heat shield to access the downpipe bolts, unplug the O2 sensor and then remove.
Old Nov 14, 2018 | 12:39 PM
^That.
The only power you're really gaining from a downpipe is from removing the catalytic converter.
Which is......illegal.
Old Nov 14, 2018 | 12:50 PM
GAFIT's Avatar
Originally Posted by mike410b
^That.
Yeah, and even the power gain from removing the cat is minimal unless you're feeding a lot of boost into the engine and need a ton more flow. Then you can still get the flow needed by using a larger/higher flowing cat.
Modern catalytic converters are darn good. Very different from the '70's-'90's where removing a cat automatically netted 10hp. Today the gain is negligible and not worth it.
Vamprie Nong
Nov 13, 2018 12:53 AM
GE8FTW
Oct 3, 2015 12:04 AM
suketoborudo00
Sep 27, 2014 07:48 PM
lidoshorty02
May 23, 2008 04:37 PM
