Just bought a Fit
Old Jan 13, 2019 | 11:02 AM
donaldfit2008's Avatar
Just bought a Fit
I just bought a Honda Fit Sport with 175k miles on it for $3600. The car drives well. Does the group have any suggestions on keeping it running for a long time? How long doe 08 Fits last? I had a 2007, and it ran over 160k until my ex-wife was hit from the side at an intersection..
Old Jan 14, 2019 | 07:11 AM
spike55_bmw's Avatar
Both the wife and car gone......
You didn't say if the new to you '08 FIT is manual / auto trans. If AT, check the dip stick, when hot, does it look / smell burnt? Not sure if you are a DIY person but changing out most of the ATF isn't that hard but takes a couple hours to get about 95% new ATF flowing through all parts.
If MT, then check hydraulic fluid level in the clutch system. If clutch not fully disengaging while shifting, you could be doing damage to synchronizers and clutch disc itself.
Check the cabin air filter for mouse nest building activities. Mice in the house damage wires in strange places that are a PITA to find / fix.
Those would be my starting places until you tell us more about your experiences with it.
Old Jan 14, 2019 | 05:31 PM
The Honda Fit Sport I bought is the 5 Speed manual transmission. Thanks
Old Jan 14, 2019 | 10:00 PM
SiXiam's Avatar
Change:
-Water pump
-Engine coolant
-Brake Fluid
-PCV Valve & washer/clamp
-Lubricate Locks, Hinges, Latches (need silcone spray)
-Inspect engine mounts
-Thermostat
-Rear drums and brakes
-Change Brake CV Joint Boots and CV axle..
-Front brakes and rotors
-Fuel filter
-Suspension
-Brake lines (all)
-Starter
-Coils and plugs
-Transmission filter/fluid
-Valve Adjustment
-Belt
-Battery (replace the ground)
-Hoses (most if not all)
-Air filter and cabin filter
I'm missing stuff, but that will help it last
uRabbit
51
May 30, 2026 01:36 PM
Andrea Cuschieri
Feb 16, 2020 06:35 AM
Farrago
Jun 24, 2019 10:41 PM
User1
Sep 29, 2017 11:32 PM
isis07734
Jul 7, 2015 10:17 AM
