Newbie here looking for some help with rear seatbelts.
Old Feb 9, 2019 | 10:20 PM
DylanCO's Avatar
Hello all, I haven't used a forum like this in about 10 years so I apologize for anything I may do wrong.
Now that that's out of the way, to make a long story short. Basically my dog chewed through the rear seatbelts in my 2010 Fit Sport. So I need to replace them before I get a ticket. I've looked online and couldn't find much info for this problem.
I couldn't figure out how to safely take the panels off to get to the belts so any help the would be great. Also what years and models would have interchangeable belt? My local junk yard currently has a '07 Fit. Would those work?
Also I'm in the US if that makes a difference.
Again thank you all in advance for any help.
Old Feb 10, 2019 | 02:17 PM
ashchuckton's Avatar
Not sure what year seatbelts will interchange. Try car-part.com you will probably be able to come up with what you need. Good luck.
car-part.com
Old Feb 10, 2019 | 06:22 PM
JerrySFL's Avatar
Rear seat belts
You need belts from a 2008-2013 Second generation . Here you go , check E-bay there are a couple of different salvage yard selling the rear belts . The interior panels you just need a panel tool to pry & release the clips see the instructions attached .
No, you need belts out of a 2008-2013 there are several available on eBay just search . They run about $ 75 a piece, As far of accessing, All the panels just snap in you need a panel release tool to pry and pull pull you need a panel release tool to pry and pull.
Dougfit
Jan 8, 2019 12:40 PM
SilverEX15
Sep 21, 2014 04:06 PM
tazman19
Mar 18, 2014 05:02 PM
Vipersnake
Dec 4, 2013 12:39 PM
