Need help!!!diy~fog light
I purchased a pair of fog lights for my 2007 FIT (base model) from Walmart. Then I followed the instruction to hook up the harness, relay and switch. Now, the challenge is I don't how to connect the on/off switch between the engine compartment and my driver seat....
Can someone tells me is there any "hole" on the firewall????
PLEASE
PLEASE
PLEASE
PLEASE
Where is it?
What i did is i used the main fusebox grommet behind the brake resivoir. It's easier to gain access from undernath the dashboard. I didn't poke a hole, i just slid off the grommet on one side of the edges and pushed the wire through, then i put the grommet back on as best as i could. it only leaves about 1mm gap. I have washed the car and engine bay many times and water has never gotten in because that particular grommet is pushed up soo far into the corner of the engine bay, water doesnt reach that area.
I don't know where is the main fuseobx grommet??Would you like to post a photo for me?!
PLEASE
Mugen_Dom
Apr 28, 2008 05:20 PM
hahaha.
